Old 10-14-2012, 03:12 PM   #1
gello88
gello88's Avatar
Fan#: 102250
What I Drive: 2000 Black ZX3
FF Reputation: 1 gello88 Good Standing Member
2000 Ford Focus ZX3 Zetec DOHC Engine Oil Leak
This has been known for a while for my car, but we cannot seem to find the source of the leak. We know that the leak comes from behind the engine block, at the passenger side. My brother looked at the bottom and saw that the highest point at which the oil seems to be leaking is at the oil pan area. Could it be that the gasket needs replacing? He also mentioned that there is an aluminum section that is part of the oil pan that could be cracked we don't know for sure. (I'm not very good with car parts). Can anyone give me suggestions as to where this leak could be coming from? As I said, so far our theory is the oil pan, gasket, and/or the aluminum part above the oil pan. Thank you.
gello88 is offline
Fan#: 1
Old 10-14-2012, 03:48 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
What I Drive: 2001 Red ZX3
FF Reputation: 82 BC_ZX3 Excellent Standing Member
Start simple: The oil filter and oil pressure warning light sensor are in this area. Before you start pulling anything apart, I'd ensure your oil filter is tightened properly and has a serviceable gasket. The gasket should be changed out during each oil filter change. Oil from the filter can dribble down to the pan.
To properly trace the source of any oil leak, clean and degrease the affected area and then look for the tell tale oil tracks.
BC_ZX3 is offline
Old 10-14-2012, 08:33 PM   #3
gello88
gello88's Avatar
Fan#: 102250
We replace the oil filter with a new one every oil change so the oil filter should not be the problem. Is there a gasket surrounding the place that the oil filter connects to or is the gasket built in on the oil filter?
gello88 is offline
Old 10-14-2012, 10:15 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
The oil filter should come with a circular, thick rubber gasket that fits snugly in a groove. However, the mating surface between that gasket and the oil filter housing should be checked for smoothness.
(I have also seen instances where the old gasket was not removed by mistake (two gaskets stacked on each other) but they tend to leak violently when under running pressure. )
If the oil filter is correctly installed and tightened, have a look at the pressure switch near it (about level with the top of the filter, more towards center of car.)
BC_ZX3 is offline
Old 10-14-2012, 11:27 PM   #5
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
I had a leak described exactly as yours, it turned out to be the pressure switch.
amc49 is offline
Old 10-15-2012, 12:22 AM   #6
PRSman25
Fan#: 103893
What I Drive: 2001 Black ZX3
FF Reputation: 1 PRSman25 Good Standing Member
If your oil filter was double gasketed, your car would have bled out and died by now.
VERY prevalent and violent leak.
PRSman25 is offline
Old 10-15-2012, 11:12 AM   #7
gello88
gello88's Avatar
Fan#: 102250
Oh okay, I'll have that checked as well. What about the oil drain plug? My brother said it has a gasket attached to it and he said it should be replaced every oil change. We haven't replaced the gasket in a while now, maybe start with that?
gello88 is offline
Old 10-15-2012, 11:36 AM   #8
grayzx35speed
grayzx35speed's Avatar
Fan#: 94839
What I Drive: 2006 Gray ZX3
FF Reputation: 0 grayzx35speed Newbie
If the oil drain plug was the issue ykur oil.leak would be right in sight and coming from the lower part of the pan where the drain plug is, not higher up on the pan.
North East Honda Killer
OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane
grayzx35speed is offline
Old 10-15-2012, 12:34 PM   #9
PRSman25
Fan#: 103893
Check the pressure switch!!!
And if that's not the case, take it to get an oil change and make sure they change the drain plug gasket.
Afterwards, clean everything that is oily, drive it about, and check for a leak or drip!
PRSman25 is offline
Old 10-15-2012, 12:38 PM   #10
gello88
gello88's Avatar
Fan#: 102250
Will check the pressure switch, seems to be located near where the leak is coming from. We just got an oil change (synthetic oil for the win!) but didn't replace the gasket, will replace it in next oil change for sure (or just get a whole new drain plug from ford to have a new start then just get new gaskets after that). I don't trust the parts in this car as we got it used a few years ago so any "new" problem that arises, we don't try to just replace gasket, we try to replace the whole related part ...
gello88 is offline
