belt tentioner. - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 10-13-2012, 06:48 PM   #1
klondike jake
Fan#: 104830
What I Drive: 2000 zx 4 door
FF Reputation: 1 klondike jake Good Standing Member
belt tentioner.
hello. can any one assist me in the removal of the serpentine belt to take off my alternator. its a zetec ,2000 yr. manual says to socket up the pully and turn clockwise. it wont go .feels like im going to break it. cant get a breaker bar and socket on it either . no clearance between the bolt and inside fender wall.
klondike jake is offline
Old 10-13-2012, 07:51 PM   #2
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,323, Level 51
Points: 6,323, Level: 51 Points: 6,323, Level: 51 Points: 6,323, Level: 51
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I use an open end wrench (I think 15mm?) with a breaker bar attached to it (Usually have to tape it to it so it doesn't slide off). And then position it in place and push forward (counterclockwise of course).
Have you tried spraying some PB Blaster in there? Sometimes it feels like you're not really moving it much but indeed you are. Maybe get someone to test the tension on the belt while you try? And have you done it before?
oh yeah, and to Focus Fanatics!
2004 ZX3 MTX - Twighlight Blue
2001 ZX3 S2 ATX - JAN 2009 ROTM - SOLD
Moderator for [Ford Focus & General Car Chat][Ford Focus Non-Performance Discussions]
Hatch Nation #29_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 10-13-2012, 08:10 PM   #3
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 2,971, Level 33
Points: 2,971, Level: 33 Points: 2,971, Level: 33 Points: 2,971, Level: 33
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 4%
FF Reputation: 9 emsvitil Good Standing Member
Jack front end up
Remove right front wheel
Remove the plastic panel under the belt from underneath.
It's 15mm.
An offset closed end or flare wrench won't slip off the nut.
Then from underneath push wrench (with extension) toward rear of car.
You can the slip the belt off the crank pulley.
Ed
emsvitil is online now
Old 10-13-2012, 08:35 PM   #4
klondike jake
Fan#: 104830
are you pushing towards the front of car or towards the rear. it wants to go towards the front but it will stop within 1.5 inches of travel.
Old 10-13-2012, 10:22 PM   #5
emsvitil
Fan#: 50210
Forum Activity 4%
From underneath the car, with the wrench hanging down from the bolt.....
You're pushing the end of the wrench to the rear of the car.
Essentially trying to tighten the bolt will tighten the tensioner against it's internal spring.
That gives you some slack in the belt.
Ed
Old 10-14-2012, 01:29 AM   #6
klondike jake
Fan#: 104830
dosnt want to move any when pushing towards the rear of the car.
Old 10-14-2012, 03:12 AM   #7
emsvitil
Fan#: 50210
Forum Activity 4%
That's weird....
I just did mine because I was changing the timing belt.
How much leverage to you have? (I had about 12 inches)
Ed
Old 10-14-2012, 12:30 PM   #8
klondike jake
Fan#: 104830
moving it back towards the back of the car ,i have zero movement.is it possible that it could have been put on diff to accept a diff belt.
Old 10-14-2012, 01:31 PM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
Points 27,391, Level 98
Points: 27,391, Level: 98 Points: 27,391, Level: 98 Points: 27,391, Level: 98
Level Up 5% Completed
Forum Activity 19%
Wait.... are you on the bolt inside the actual pulley, or on the bolt holding the center of the tensioner arm? You should be on the bolt in the center of the actual pulley itself, moving it clockwise will rotate the pulley up so that you can slip the belt off another pulley- usually an idler where the back of the belt rides on the pulley.
As far as belt routing, you'll have to use your head on that one. If moving the pulley up and away puts more tension on the belt, then that's obviously the wrong way to go. You might want to check to be sure that your belt routing matches what is in your manual, or at least draw it out on paper before you remove the belt.
Did someone remove AC from this car or something?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-14-2012, 08:19 PM   #10
klondike jake
Fan#: 104830
I GOT IT.i want to thank every one for your help. i feel kinda dumb,but it just needed more force than i thought to get it to finally go. thanx again.
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
