Puddle of water on passenger side floor - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Second Generation > MK2 Focus
Old 10-13-2012, 01:27 PM   #1
popcornuk
Fan#: 95052
What I Drive: Focus 2003 Silver LX 1.8L
FF Reputation: 1 popcornuk Good Standing Member
Exclamation Puddle of water on passenger side floor
Hello all,
Looking for some suggestions as to what could be the cause.
After a very rainy day and high winds, I noticed a pretty big puddle of water on the driver side floor. It was that deep that the water started sloshing about when the car was moving.
I checked everything else and it was bone dry. There was no water on the inside of the driver side window or windscreen. The glovebox and panel behind it was also dry so I've no idea where it could be coming from.
I've checked online and it seems to be a common problem caused by a bulkhead, hole in the wheel guard or a leak in the radiator system.
It's been raining again today although nowhere near as bad and there doesn't seem to be any fresh water.
Should I take this straight to the garage?
Cheers
popcornuk is offline
Old 10-13-2012, 02:33 PM   #2
Also-ran
Also-ran's Avatar
Fan#: 100107
What I Drive: 2010 Black Focus SES
FF Reputation: 1 Also-ran Good Standing Member
My first thought is to check the bottom of the door to make sure the drain holes are clear. Checking for a sloshing sound inside the door will help you diagnose if these drains are the issue. Do the same for the rear passenger, in case the issue is there and the water has flowed forward to your feet.
The AC drain would be the alternative thing to check, if the doors are okay. But enough water to slosh around during a rain storm in the middle of October doesn't really sound like the AC drain. It's just a CYA thing to check that might end up saving you a bill from the mechanic.
Also-ran is offline
Old 10-13-2012, 02:37 PM   #3
popcornuk
Fan#: 95052
I had a listen for sloshing sounds when I was out driving today and couldn't hear anything.
When you mention the drain holes, where am I looking? Directly under the door when it's open?
Cheers!
Old 10-13-2012, 05:36 PM   #4
Also-ran
Also-ran's Avatar
Fan#: 100107
Correct; on my car there is a little black plastic rectangle shaped plug on the bottom of the door, towards the front end of the car. It pops out to expose a 2 inch long drain hole.
Also-ran is offline
Old 10-13-2012, 06:45 PM   #5
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Very common issue. Usually due to the seal failing on the passenger side window cowl. Take a look and see if it's loose or not fitted properly.
2004 ZX3 MTX - Twighlight Blue
2001 ZX3 S2 ATX - JAN 2009 ROTM - SOLD
Moderator for [Ford Focus & General Car Chat][Ford Focus Non-Performance Discussions]
Hatch Nation #29_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
