Why you should retrofit your lights - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-13-2012, 12:01 AM   #1
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
Hey guys, just gonna post some pics of my retrofit and why it's awesome to do!
Halogen pics: Silverstar ultras, 3000k HID fogs
HID pics: Morimoto Mini H1 6000k, 6000k Fogs
Retrofitting
On the car
Light output
Lows with fogs, this comparison will not be accurate because the halogens had 3000k hid fogs and the hid pics have 6000k headlights and fogs, but i will include them anyway.
Low beam alone
Highbeam
The main comparison point is the highbeam and how much light is available. I had an issue with a headlight adjuster breaking, but a member on here mailed me one from a junk headlight.
Yes I still need to aim the low beams with projectors up so I can see a little further, but it is awesome on highbeam!!!
More pics in post #18
A7xschecter6661 is offline
Old 10-13-2012, 01:26 AM   #2
Slammed_2.0
Boosted HB.
Slammed_2.0's Avatar
Fan#: 84306
What I Drive: 2013 TB ST
Points 6,542, Level 52
Points: 6,542, Level: 52 Points: 6,542, Level: 52 Points: 6,542, Level: 52
Level Up 96% Completed
FF Reputation: 20 Slammed_2.0 Great Standing Member
Buy-Sell-Trade Rating: (4)
Wayyyy too low
2013 Ford Focus BOOS[ST]ED
2010 Ford Focus "S"edan (11 Psi, GT28RS) - Sold
ROTM Nov '11 (2010 Focus S)
Slammed_2.0 is offline
Old 10-13-2012, 09:43 AM   #3
A7xschecter6661
Fan#: 98263
Originally Posted by Slammed_2.0 View Post
Wayyyy too low
Yah yah, already broke one adjuster and they aren't easy at all to get ahold of.
Beam needs to go out about 10 more feet, but I feel like the driver adjuster wants to snap again, the passenger one moves freely
Then both projectors are slightly rotated, but it's not driving me nuts enough to adjust them lol
Old 10-14-2012, 12:17 PM   #4
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,263, Level 19
Points: 1,263, Level: 19 Points: 1,263, Level: 19 Points: 1,263, Level: 19
Level Up 63% Completed
Forum Activity 4%
FF Reputation: 1 popwarhomie Good Standing Member
Yay im still the only one that left the bars in my headlights with my retrofit
Looks good. Def need to be aimed up more though like you said.
2010 Focus SE coupe 5 speed
Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/Projector retrofit/LED tails/ Walled with 2 SQ HDC3 18s.
94 Lightning
A lot of mods.
popwarhomie is online now
Old 10-14-2012, 01:40 PM   #5
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
I wonder how hard it would be to paint the black housing to color match your paint and if that would look good?
If you could do your retrofit all over again, which kit would you use and why... Links to said kit is a must
If you can't wear it out, burn it off
DarderSauce is offline
Old 10-14-2012, 03:14 PM   #6
popwarhomie
Fan#: 94974
Forum Activity 4%
I have Morimoto MH1 4.1/ E46-R shrouds/ Morimoto 3Five ballast and 3Five 5000k bulbs.
I love mine(4.1) but I would like to try the MH1 5.0 because they now have foreground limiters, better highbeam solenoids, Better lens,and blocked squirrel finders.
http://www.theretrofitsource.com/pro...roducts_id=227
Im planning on running FXRs some day but I still love my MH1s
94 Lightning
A lot of mods.
Old 10-14-2012, 05:01 PM   #7
A7xschecter6661
Fan#: 98263
I have the Moritmoto MH1 Version 5.0s
The whole kit is $270 for projectors, bulbs, ballasts, wiring harness, and shrouds.
I was going to paint everything black but it was just one more thing that could get messed up, and this took me long enough to do (with the adjuster breaking and getting a bad highbeam relay). Everyone that has seen them in person says they look awesome in chrome and like the could be 100% stock. I also considered buying my color paint and doing the housings, but like the above another thing to wait for and mess up.
I did not leave the bars in the headlight because I figured they might get in the way of the beam, though they probably wouldn't have.
I have the headlights aimed up higher, but I still feel like the new adjuster I got is going to break, so I am not pushing it, I am almost always on highbeam so it does not matter to me anyway.
Maybe I will snap a few more pics tonight since I aimed them up more
Old 10-14-2012, 05:19 PM   #8
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,939, Level 87
Points: 18,939, Level: 87 Points: 18,939, Level: 87 Points: 18,939, Level: 87
Level Up 18% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
Exactly how hard was it to pull these apart and do those little pieces of plastic serve a purpose? because if I where to pull mine apart I'd just do it to remove those pieces of plastic
badazz2010focus is online now
Old 10-14-2012, 09:37 PM   #9
A7xschecter6661
Fan#: 98263
Literally the hardest part is pulling the lenses off.
I did 280 degrees for 15-20 mins in the oven and slowly worked my way around the lens with a screw driver.
Eventually you get enough loosened and it just pops apart.
Then you take out the halogen metal reflector that says "focus". Grind a little around the hole so the bowl of the reflector sits in the old bulb hole correctly. Tighten the nut on the back.
The picture of these
http://www.theretrofitsource.com/pro...oducts_id=3181
shows you what they look like. On the back side it is threaded with a nut. So basically you open your housing, take the metal "focus" piece out, round out the hole, drill a small hole below it for the solenoid wires to run through, slide projector in, and tighten the nut on the back, aim and reseal.
Put them on the car and aim them, pull them off and tighten the nut more. Put them back on the car and check the aim again, do the final tighten, put them back on and make sure you got it right
Then I took a heat gun and went around the inside channel where the lens pops in and peeled all the old adhesive out. Then put in 3M window-weld butyl tape and heated it then replaced the lens.
It's honestly a few hour project. I took all day to do it like 10am-6pm, but that included running out to try to find a new aimer and taking it nice and slow. If I did it again I could probably do it in 3-4 hours if I was moving quick.
It's honestly very easy and the output is so much better than stock. Finally HIDs without getting flashed!
Slammed 2.0 has a "how to" on it here
http://www.focusfanatics.com/forum/showthread.php?t=264843
I followed that and it worked fine for me, there is one picture that looks very tricky because of the chrome reflector. His looks like he actually cut a hole in the whole back of the reflector.
This is his picture where it looks like he cut the reflector and just has the lens inside the housing.
This is how it actually looks, more from the side so you see the back bowl of the projector
Old 10-14-2012, 09:49 PM   #10
badazz2010focus
Fan#: 78166
Forum Activity 7%
I wouldnt be pulling them apart to retrofit I'd pull them apart to get rid of the plastic pieces...they dont serve any purpose do they?
