way to charge phone and have phone outside of center counseL? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-12-2012, 06:14 PM   #1
k1ngkev1n1
Fan#: 103124
What I Drive: 2012 ford focus SEL
Points 3,289, Level 35
Points: 3,289, Level: 35 Points: 3,289, Level: 35 Points: 3,289, Level: 35
Level Up 60% Completed
FF Reputation: 1 k1ngkev1n1 Good Standing Member
In my previous car there was an opening in the center counsel that allowed for the cable to run outside of the center counsel is there a way with the focus? or has anyone drilled a small hole for a charging cable ? curious what others have done. I would rather not used the 12v outside the center counsel.
k1ngkev1n1 is offline
Old 10-12-2012, 06:37 PM   #2
wilsonfocus86
wilsonfocus86's Avatar
Fan#: 23099
What I Drive: 14 Fusion 2.0
FF Reputation: 3 wilsonfocus86 Good Standing Member
There kinda pretty much is an "out-hole"-ish but once you close the lid to the arm rest whatever length your cord is at, that's all the slack you get/have. At least that's what I know you can do/I've done.
"If in doubt.. Flat out." - Colin McRae
wilsonfocus86 is offline
Old 10-12-2012, 06:40 PM   #3
lddavis
Fan#: 104180
What I Drive: 1997 Red Outback
FF Reputation: 2 lddavis Good Standing Member
In the 2012's (I've mostly looked at the ST) there is a groove in the front side of the center console box that allows cables out.
You probably do want a notch from the top, rather than a hole, because the hole would have to be big enough for the connectors, much wider than the cable itself.
lddavis is offline
Old 10-12-2012, 10:38 PM   #4
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
Actually that slot isn't for a cable. That slot is for the lid to center and to keep the hinge safe (to keep it centered).
When you close the lid a plastic "tooth" drops down into that groove and goes all the way to the bottom. The better part is the corners of the lid don't close tightly, so I just leave the cable sitting on the corner when I close the lid.
hotleadsingerguy is offline
Old 10-12-2012, 10:50 PM   #5
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
Noticed that as well but there's not even a mark on my iPod cable where I've closed it in the groove, so I usually just do that anyway.
Sonic Crew #28
feta_mgp is offline
Old 10-12-2012, 11:02 PM   #6
Power Surge
Fan#: 55878
What I Drive: 2012 Race Red SE 5-door
FF Reputation: 1 Power Surge Good Standing Member
Different trim levels might have different consoles, but on my SE sport, I have a cable groove in mine that is large enough to fit a finger down into it and there is clearly nothing on the lid that matches up with it. It's definitely a cable groove.
Sal
2012 Race Red 5-door SE, 18" Ti wheels, Ti headlights/fog bezels, 20% tint, debadged trunk
2002 Sonic Blue SVT - supercharged (sold)
2008 Vista Blue SE (gone)
Power Surge is offline
Old 10-12-2012, 11:55 PM   #7
hotleadsingerguy
Fan#: 86687
You talking about the direct center of the front of the console when it's open? Look at the end of your lid again...because they gave me an SE rental and it had the same exact groove as mine, and the plastic tooth was there too.
It's a way of stopping the hinge from breaking from people pushing the console horizontally.
Old 10-13-2012, 12:47 PM   #8
Power Surge
Fan#: 55878
No, its definitely a cable guide. It's off center to the pass side, about 5/8" deep, and there is nothing on the lid that corresponds to it. There is also no notch like you describe on either the lid or console for "centering".
Sal
Old 10-13-2012, 01:12 PM   #9
macatron
macatron's Avatar
Fan#: 65326
What I Drive: 2012 Blue Candy Focus Ti Hatchback
FF Reputation: 1 macatron Good Standing Member
This is what I do on my SEL too. It's not perfect, but at least my USB cable doesn't get messed up like it was when I tried routing out the middle of where the lid closes. This is definitely an oversight on Ford's end though because most cars offer a actual cutout for things like this (especially if all the media connections are located IN the center console).
macatron is offline
Old 10-13-2012, 01:58 PM   #10
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
That's correct. That groove is only in the S/SE (the consoles with the fore/aft cupholders).
Hatch Nation #90
TboneZX3 is offline
