need help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-11-2012, 09:57 PM   #1
j2blaze420
Fan#: 104758
What I Drive: 2003 white zx3
FF Reputation: 1 j2blaze420 Good Standing Member
need help
i cant figure out why my car is idling rough and low and acts like it wants to stall i replaced plugs and upstream o2 sensor since thats what the cel said it was and replaced egr sensor and line any ideas on whatto do next would be helpful
j2blaze420 is offline
Old 10-11-2012, 10:07 PM   #2
rangerbay
Fan#: 76247
What I Drive: 2001 white zts,2001 white wagon,
Points 211, Level 4
Points: 211, Level: 4 Points: 211, Level: 4 Points: 211, Level: 4
Level Up 22% Completed
FF Reputation: 2 rangerbay Good Standing Member
Check you hoses for crimps or leaks. Then check to make sure you're getting spark to all cylinders.
I had a crankcase vent tube crimp causing a bad idle. It was crimped at the rear of the motor, you had to follow the rubber tube to the back to find it. It starts out as ametal tube from the crancase, drivers side front, and goes into a rubber tube under the thermostat housing. Follow it from there. That could be your problem.
Bill
rangerbay is offline
Old 10-12-2012, 12:59 AM   #3
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Might want to also check tps sensor readings and idle air control valve. I've also seen a weak alternator cause similar symptoms.
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
Old 10-12-2012, 04:46 PM   #4
j2blaze420
Fan#: 104758
how would i go about checking to see if im getting spark to all cylinders im not gonna lie im no mechanic but i refuse to pay tons of money to have a shop look at it
Old 10-12-2012, 05:53 PM   #5
rangerbay
Fan#: 76247
Points 211, Level 4
Turn the engine on, then barely pull one plug wire off the coil pack and keep it right at the tip of coil. Spark should jump the the plug wire. Do that for all 4. If you're getting spark there, then check the spark at the spark plug, same way. If you have spark at the coil, but not at the plug= bad plug wire.
Did you check the hoses? That is the first thing I'd check.
Bill
Old 10-15-2012, 01:40 PM   #6
j2blaze420
Fan#: 104758
i checked the hoses couldnt find a leak i was gonna try and check the iac do you know the easiest way to remove it
