Yellow ! Star pattern light - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-11-2012, 09:18 PM   #1
bumble21
Fan#: 95826
What I Drive: 2001, Black&Yellow, ZX3
FF Reputation: 1 bumble21 Good Standing Member
I have a 2001 ford focus zx3 with 175k on the odo. My blower motor only works on the 4th setting. I turned the blower motor on for heat or ac doesn't matter which same result. I was going about 55 in 4th gear and it felt like the front end of my car just dipped down like an all of a sudden loss of power. Right when I turned the blower on the light came on for about 5 seconds and shut off. This happens whenever at high rpm 3k + or so. If at idle it will not happen or jut normal cruising. At night even at normal cruising speeds my lights do flicker. I'm not sure why the light came on or what could be wrong any help would be much appreciated. Thank you in advance for your responses
bumble21 is offline
Old 10-11-2012, 09:52 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 163, Level 3
Points: 163, Level: 3 Points: 163, Level: 3 Points: 163, Level: 3
Level Up 26% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Your blower motor resistor is probably bad. It should be located in the HVAC duct near the blower motor. It is used for the three lower speeds, but is bypassed for the high speed.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 10-11-2012, 10:40 PM   #3
bumble21
Fan#: 95826
I will try replacing it tomorrow. Is it the same for all the 00-04 focus' like most other parts? Will this cure the problem or just one? I just found it odd that something electric could cause a performance loss like that
bumble21 is offline
Old 10-12-2012, 07:48 PM   #4
MEJY1988
Fan#: 101883
Points 163, Level 3
This is will only fix the three lower speeds of the blower motor. For the flickering lights check all your main power connections. The connections on the battery, alternator, grounds, ect. Check visually and for tightness and for corrosion.
MEJY1988 is offline
Old 10-14-2012, 10:00 PM   #5
bumble21
Fan#: 95826
I replaced the resistors and tightened up my battery connections and everything is running well now. Thanks again
bumble21 is offline
