#1 | ||||
2001 Zetec won't start at all
I'm a driver for a pizza place. Yesterday, after a usual delivery, I went back to my car, turned the key and nothing happened... at all. No sound, I can't even hear anything TRY to start.
The battery is still good, the interior lights still work, it beeps when you have the door open with the key in, but it will not unlock the transmission, start, or turn on headlights/breaklights. The four-ways still work. My Grandpa said he thought that maybe the battery was bad, but it is less than a year old, and all the interior lights are still as bright as ever. The guy that towed it home for me said that the ignition is known to go bad and can cause similar problems. I don't want to replace the ignition if I'm not sure that is the real problem. Especially if I have to get my keys reprogrammed. Any info that might help could be greatly appreciated. Also, I don't have any device to access the computer, but I know someone that may (possibly) let me borrow one if that info would help, we aren't on great terms with each other right now though. |
Remove Advertisements |
Fan#: 1
#4 | ||||
xxMichaelAnthony it is auto
iminhell, do you think it is worth replacing the ignition? Is there maybe a way I could test it to make sure that's the problem first? (I tried to use the multi-quote button but it doesn't seem to be working for me, sorry) |
#5 | ||||
Well either way, check the neutral safety switch. Not sure where it is on the autos. I know exactly where it is on the manuals, thats why I asked. I have the same problem you have due to the neutral safety switch but only intermittently and mine is a 5 speed
http://effyeahsmallfords.tumblr.com [HOONIGAN] iTroll |
#6 | ||||
Thanks for the help guys! |
#7 | ||||
neutral safety switch -
An electric switch that is connected to the ignition switch of an internal combustion engine and prevents starting the engine unless the transmission shift lever is in the neutral or park position, or the clutch pedal is depressed. Hope that explains it. haha. I would check it first. Definitely the cheaper part vs the ignition and its something you would probably be able to do with out a hitch.
#8 | ||||
#9 | ||||
Sooner the better. haha I also deliver pizzas. I know how it is dealing with car problems and having to work.
#10 | ||||
Thanks a lot guys, but today we found out it was just a combo of a bad fuse and a bad relay. Luckily my grandpa had some extras he had bought for his car. Everything is back to normal now. :)
Actually, while checking stuff I did find a small leak in my antifreeze container that I plan to fix tomorrow, but that's no big deal. At least I didn't have to replace the ignition! |
| Thread Tools | |
| Display Modes | |
