2012 focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-10-2012, 01:24 PM   #1
lexi321cat
Fan#: 95012
What I Drive: 2012 candy red se 5 door
FF Reputation: 1 lexi321cat Good Standing Member
2012 focus
Any one have Transmission problems with there 2012 focus like slipping? Its like driving a standard with the clutch going.But I have an automatic.
lexi321cat is offline
Old 10-10-2012, 01:44 PM   #2
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
What I Drive: Slammed S-10
Points 8,062, Level 60
Points: 8,062, Level: 60 Points: 8,062, Level: 60 Points: 8,062, Level: 60
Level Up 56% Completed
FF Reputation: 7 Chaos09 Good Standing Member
Use the search function. There are multiple threads on this. Looks in the MK3 section and you will find everything you need.
Sonic's MK3 Crew #9 Chaos!
Chaos09 is offline
Old 10-11-2012, 11:38 AM   #3
Kevastator
Kevastator's Avatar
Fan#: 104674
What I Drive: 05 Slowbaru Outback
FF Reputation: 2 Kevastator Good Standing Member
I believe Ford did a recall for the 2012 automatics a little while back. Was your car affected by that, and if so, has it been repaired?
Kevastator is offline
Old 10-12-2012, 08:53 AM   #4
lexi321cat
Fan#: 95012
that was for roll back
Old 10-12-2012, 12:04 PM   #5
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,436, Level 93
Points: 22,436, Level: 93 Points: 22,436, Level: 93 Points: 22,436, Level: 93
Level Up 9% Completed
Forum Activity 12%
FF Reputation: 10 Twenty Great Standing Member
Technically it IS a manual, and not an automatic. It may not be what you're used to, perhaps combined with an actual problem, but keep that in mind.
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 10-12-2012, 05:00 PM   #6
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,079, Level 34
Points: 3,079, Level: 34 Points: 3,079, Level: 34 Points: 3,079, Level: 34
Level Up 20% Completed
Forum Activity 3%
FF Reputation: 15 PratoN Great Standing Member
This is probably where my future posts on this topic belong.
What is your build date? There is a TSB (11-12-13) published on December 23, 2011 that states some cars might have transmission fluid leaking where the bell housing meets the engine. If you have this, get it fixed.
Unfortunately, the literature states nothing about the symptoms other than the leak. But from what I've heard from others that have this issue, their car makes a "grinding" or "rattling" noise while shifting (almost always into 2nd, 4th, 6th, and reverse due to their design sharing the same clutch) as well as slipping while accelerating on level ground and/or keeping steady speeds uphill.
If you don't have the transmission fluid under your vehicle, I presume we're in the same boat. I dropped my car off at the dealership this morning because of the slipping and mentioned someone I knew had the same noise except their car was leaking transmission fluid and mine isn't. I hope that steered them in the right direction. I don't want to have to go in there and say "Here is TSB 11-12-13. This is the issue. Fix it." because I'm only 99% certain that it is and to go over their heads seems rude.
PratoN is online now
Old 10-16-2012, 12:24 PM   #7
ccelaya
ccelaya's Avatar
Fan#: 92465
What I Drive: 2012 Sterling Grey - Focus HB Sport
FF Reputation: 1 ccelaya Good Standing Member
I have the grinding noise, and got a "transmission malfunction, service now" message some weeks ago. Where should I be looking for the fluid leak?... With this I would have enough arguments to get my transmission fixed.
Thanks!
ccelaya is offline
Old 10-17-2012, 04:37 PM   #8
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 3%
Take off the aero shield as if you were changing your oil (you'll need a T30 Torx bit). If there is a slick fluid leaking between the engine and bell housing, you've got a problem! If it's thick / honey-colored that's just corrosion inhibitor, don't worry about it.
Old 10-17-2012, 06:02 PM   #9
ccelaya
ccelaya's Avatar
Fan#: 92465
Thanks a lot, I'll take a look this weekend
ccelaya is offline
Old 10-21-2012, 02:25 AM   #10
matt1975
Fan#: 105105
What I Drive: 2012 Focus SEL
FF Reputation: 1 matt1975 Good Standing Member
I'm also experiencing the Grinding sound when I accelerate but mostly when I accelerate while making a right turn and My car shudders like the transmission is slipping when i start off It last from the start of 1st gear and continues until I reach second gear.. I plan on taking it to the service department on monday but they will probably just play it off as nothing or try to convince me that it's all in my head like they always do..but I'll keep bringing it in until it's fixed..
matt1975 is offline
