Go Back   Focus Fanatics > Model Specific Discussions > MK2 Focus
Old 10-10-2012, 05:57 PM   #11
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2005 ST
FF Reputation: 4 05focusST91 Good Standing Member
It could be a bad strut mount, make sure the nut in the middle under the hood on that side is tight
D23 crew #27, the look on their face when they see foci taillights
05focusST91 is online now
Old 10-10-2012, 07:38 PM   #12
Slammed_2.0
Boosted HB.
Slammed_2.0's Avatar
Fan#: 84306
What I Drive: 2013 TB ST
FF Reputation: 19 Slammed_2.0 Great Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by Gettysburg150 View Post
Hitting what metal?
Side of fender well. It's all aluminum.
Strut mount will cause clunking
2013 Ford Focus BOOS[ST]ED
2010 Ford Focus "S"edan (11 Psi, GT28RS) - Sold
ROTM Nov '11 (2010 Focus S)
Slammed_2.0 is offline
Old 10-11-2012, 07:07 AM   #13
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
FF Reputation: 2 Gettysburg150 Good Standing Member
By strut mount, do you mean the bearing? It was ok when I inspected upon install though I did not replace it, maybe its worn. I will double check the strut nut (hehe) to make sure all is still tight (double hehe)
If the sway link is contacting the fender well wouldn't that mean the control arm bushings are bad and letting the control arm walk? I know I see a lot of BMW's do that
Sedan Revolution Two Three Zero
FRPP, Debadged, Lots of plans, little time, zero money...
Gettysburg150 is offline
Old 10-22-2012, 09:29 AM   #14
Gettysburg150
Fan#: 97408
UPDATE:
It seems I have found and corrected the issue. Checking all suspension components everything looked good. Sway links are good, control arm bushings are good, ball joints are good, strut pinch bolts are tight.
I thought to myself, ok, everything looks good, lets double check the top and see that it's still all tight. Checked the three nuts on the top of the strut tower, those were all good. Put a wrench on the passenger side strut nut (the one that holds the top hat and everything together) and I was able to tighten it up a good bit. Test drove and no further noises heard (other than the traditional rear creek from the parking brake cables).
I know other guys have had the same concern, check that nut and make sure its very tight. I was able to get about a 1/4 turn out of the drivers side and a 1/2 turn out of the passenger side. No more rattles/clicks over bumps and uneven roads.
