New here 2003 zx3 5 speed long intro :) - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-25-2012, 02:29 AM   #21
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,744, Level 78
Points: 14,744, Level: 78 Points: 14,744, Level: 78 Points: 14,744, Level: 78
Level Up 74% Completed
Forum Activity 9%
FF Reputation: 90 goinloco1 Excellent Standing Member
meant get rid of the elbow and blue connector. the filter will then sit behind the headlight.
goinloco1 is online now
Old 10-25-2012, 06:03 AM   #22
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
For correcting flow on the MAF- it's flat, looks like a credit card sort of. There are 2 holes that the air flows through. One is near the connector, and one is on the opposite corner. The one nearest the connector is where the air flows out, and the one furthest away from the connector is where air flows in.
If that's not the problem then you need to post a thread in General Technical Chat. This particular thread should be in Duratec Performance. Moving it to Tech chat won't do you any good. People who answer threads in there don't usually answer new threads with 3 pages. Once we get a problem, we latch on to it until it's resolved, then move on.
If you want, you can mess with your buddy. Ask him how he thinks you're supposed to change the timing belt since the valve cover doesn't have a timing belt inspection cover.
Moved to Duratec Performance.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 10-25-2012, 09:58 AM   #23
gaspricessuc
Fan#: 104687
What I Drive: 2003 Primer ZX3
FF Reputation: 1 gaspricessuc Good Standing Member
Got rid of the elbow and blue connector and intake does sit between battery and headlight, and maf can not be turned around.
also a reply on focaljet
"There should be a place for an air straightener a white grid plastic peice that fits in the end of the MAF tube, that should face down toward the filter. I don't know if that's your problem but it's worth a try."
gaspricessuc is offline
Old 10-25-2012, 06:12 PM   #24
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Well if it can't be turned around, then maybe that tube was put in backwards. Did you look at the holes in the MAF as I described to see if it was turned around the right way?
If it's pointed the right way, then it is not the problem unless the wiring is damaged somehow. From what you described, it could be the TPS, you'll have to get out your multi-meter and test it to see if the resistance is correct.
Be eclectic.
Old 10-25-2012, 06:48 PM   #25
gaspricessuc
Fan#: 104687
Yes sir the holes linded up when I put it in, that is the only way it was to be bolted.
I had a few codes before I Fixed the pcv line I shall post them now
p0171 system too lean
p0102 maf (fixed that)
p0113 intake air temp
p0452 evap system pressur sensor low input
p0453 same as 52
p2004 intake manfiold aka the pcv hose (fixed)
p2008 same as 04
p0068 throttle
Old 10-28-2012, 01:40 PM   #26
gaspricessuc
Fan#: 104687
Update. Replaced drivers seat with one from junk yard. While I was thereby asked my father what color mine were and he said grey so I get a grey seat like the 4 door. One seats are black. Oh well I'll get seat covers
Old 11-03-2012, 06:19 PM   #27
gaspricessuc
Fan#: 104687
Update, took it to my ford dealership, found a bad wire in a maf harness so they fixed that and replaced something else, only is throwing two more codes now, a intake runner code, there is a bad wire there, and a fuel pressure, they noticed the gas tank was dropped so they were thinking when the person put the tank up they crushed the harness.
already giving them $410 to fix the maf problem, also the maf elbow was backwards.
Here is the pic with the new hub cap on and new grey seat in -_-
