Smoke coming from 2002 Zetec by dipstick - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-09-2012, 12:13 AM   #1
weirdal1968
Fan#: 91017
What I Drive: 2002 Red Zetec SE Wagon
Points 205, Level 4
Points: 205, Level: 4 Points: 205, Level: 4 Points: 205, Level: 4
Level Up 10% Completed
FF Reputation: 1 weirdal1968 Good Standing Member
2002 Zetec SE wagon 166K
I'm pretty green when it comes to car repair. It took me a week to change out the alternator last year. Spent a few days to do the thermostat housing (but now I could do it in my sleep). Changed out the EGR valve relatively easily.
Just had an oil change and it was down to the add oil mark so something is amiss. It's leaking oil around the valve cover and the seal was replaced at a shop less than a year ago. That's probably the PCV line issue mentioned in the forum. That will be addressed when I get a replacement PCV line.
When I crank + idle, after about a minute I see a plume of white smoke rising from the area between the oil dipstick and the engine block. It looks like its coming from deep between the two but I couldn't see the source. Heck I don't know for sure if this is oil or coolant smoke. Like I said - I'm still a noob.
weirdal1968 is offline
Old 10-09-2012, 02:03 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
Being the exhaust in near that area and a source of heat, enough heat to 'burn' (not combust/ignite) oil; odds are it's oil leaking onto the exhaust.
The oil in the pan does not reach the level of the entry point of the dipstick tube into the engine block.
But oil splashing around could make it's way past the O-ring seal on the bottom of the dipstick tube.
If that's the area you think is the problem then I would take the dipstick tube out and inspect the O-ring for damage.
Simply remove the 1 retaining bolt on the cylinder head, twist and pull gently on the tube. It should come out relatively easy.
Do be sure first that there is no debris that will fall into the oil.
121,000 members and still no sponsored racing.
iminhell is offline
Old 10-09-2012, 06:09 PM   #3
weirdal1968
Fan#: 91017
Points 205, Level 4
Thanks for the pointers. I'll take a look underneath once I borrow some stands from a neighbor. Wednesday I will have the new PCV valve and hose so I should be able to take a closer look at the oil dipstick tube.
Will I lose a significant amount of oil when I remove the tube? Should I have a catch pan ready?
Old 10-09-2012, 06:16 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 10%
Won't loose any. As I said, the oil level isn't that high.
iminhell is offline
Old 10-09-2012, 07:35 PM   #5
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Could easily be valve cover leak (if leak in front) runoff dripping to get to that point too.
amc49 is offline
Old 10-12-2012, 06:29 PM   #6
weirdal1968
Fan#: 91017
Points 205, Level 4
The leak is more prominent on the passenger side and it has been leaking for a long time. Directly underneath there is a bolted on pan that was COVERED in leaked oil. The other side is probably why a replacement thermostat housing failed after less than 6 months. One of the bolt holes showed signs of melting - probably from the hot oil.
Now for the good news...
The dealership ordered the wrong part so I didn't get the right one until Thursday. Worked until after dark to chop out the old line and it had collapsed flat. The end near the EGR valve came off with 15 minutes work but the other end was a knucklebuster. I had to take a razorblade and carefully chop chunks off the hose until the nipple was exposed. The clamp absolutely would not budge so I gave up for the night. Today I examined a clear pic of the single use clamp and figured out where I needed to push to make it release. Nailed it on the first try! Hold the blade of a flathead screwdriver parallel to the clamp from the drivers side and push against the bump in the middle. It didn't take much pressure because I had removed most of the deteriorated hose. YMMV. Installing the new hose was a cakewalk and I didn't have to remove the black box or even move the power steering tank. Used a new regular hose clamp and cinched it down until it was just tight enough.
Due to all the oil that had leaked I used the remainder of a can of MAF sensor cleaner to wash off the dirty spots so I could easily spot the leak source. Washed and waited for the cleaner to evaporate. Started her up and the idle was definitely quieter. Still lots of vibration but I haven't replaced the PCV valve yet. Ran a bunch of errands and the white smoke never returned so I think it was just the valve cover leak causing most of my problems. Drove for at least 45 minutes and the lip around the valve cover stayed free of oil so I think I might be in the clear.
Once I replace the PCV valve, I want to try my hand at Sea Foam to clean out the gunk. At 166K I suspect there is some evil snot hanging out in the system. I'm also planning on trying my hand at my first DIY oil and filter change since I'll need to do that after the treatment.
Old 10-14-2012, 06:55 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,422, Level 75
Points: 13,422, Level: 75 Points: 13,422, Level: 75 Points: 13,422, Level: 75
Level Up 44% Completed
Forum Activity 99%
Hey!
Good Luck, You're getting there...
We were ALL 'Newbies" once, only way to get familiar with the things is to work on them - and it feels good when it works right & YOU did it!
Plus it's cheaper than paying someone who may not care about it like you do....
Always figured that even if it was a "break even" after buying tools, I was STILL ahead - 'cause I learned something, got it done right, and had the tools on hand for future projects...
Luck!
sailor is offline
Old 10-14-2012, 07:26 PM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Eh... Seafoam.... You'll be better off not doing it, but ok. All that stuff you break loose will end up in the catalytic converter. You'd best leave it in there.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-14-2012, 10:45 PM   #9
weirdal1968
Fan#: 91017
Points 205, Level 4
The engine is still running rough and its high mileage so I'm willing to take a chance on Seafoam. Given that she ran with a serious oil leak/vacuum leak for multiple oil changes there is probably an ungodly mess of carbon buildup inside. I'll take the chance on the cat as I live in an area w/o emissions testing and I haven't seen any reports of cat damage.
The valve cover is leak free today even after another two hours of in-town driving. I still sometimes catch a whiff of burnt oil when I pull into the driveway but nowhere as bad as before. Probably just the previously leaked oil cooking off.
