About to Buy a 2003 SVT, HELP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 10-08-2012, 07:45 PM   #1
cassard
Fan#: 104644
What I Drive: 1996 C36 AMG mercedes
FF Reputation: 1 cassard Good Standing Member
Hi guys, I'm about to buy a Ford Focus SVT 2003 with 118 00 KM, So it would be around 73 000 Miles in USA. (I'm in Canada)
I'd like to know if there is some particular problems or issues with the car that I should look for.
I know the guy is replacing the Variable Cam Pulley (I don't know if you say that in english, I only know the french terms)
But for the rest, I have no Idea. I'm more of an European car guy, but I need a 4 seasons car. So I'm about to drive it in winter also.
If you guy have anything to say about this car please do. I want to be sure I buy something that won't break 2 month after I bought it.
Thank you !
cassard is offline
Old 10-08-2012, 10:36 PM   #2
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
Timing belt
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 10-09-2012, 01:06 PM   #3
Ford Fanatic
Fan#: 104637
What I Drive: '03 SVTF 5 door & built '03 mustang
FF Reputation: 1 Ford Fanatic Good Standing Member
Same situation here! I bought a 2003 svtf with 76k on it yesterday. completely stock with "zero problems". I did a little research here and there on this site and everyone was saying the same thing about the timing belt..
can someone elaborate a little more for me regarding the timing belt? This will also be my new DD (i live it Michigan) so ill also be slugging this bad boy through the snow. any tips or known problems this car has regarding the snow?
2003 Mustang GT - 13.1 1/4 N/A auto
2003 SVTF 5 door- stock (for now) daily driver
Ford Fanatic is offline
Old 10-09-2012, 01:19 PM   #4
swansong
swansong's Avatar
Fan#: 83576
What I Drive: 2008 Saab 9-3 Aero SportCombi XWD
Points 2,305, Level 29
Points: 2,305, Level: 29 Points: 2,305, Level: 29 Points: 2,305, Level: 29
Level Up 4% Completed
FF Reputation: 12 swansong Great Standing Member
Buy-Sell-Trade Rating: (4)
The SVT engine is an interference engine, which means when the timing belt goes it usually takes the pistons, valves, and other good stuff with it. So the belt should be changed every 80k miles. I'm calling these numbers off the top of my head, but I believe parts to do the job run about $200, and dealers typically charge anywhere between $500-$1000 to do it. It's doable for a DIYer, but experience, time, and tools are needed.
The clutch *might* also be a concern at that mileage. Ask if it has had the clutch replaced under the TSB, which was typically performed early in a car's life due to premature clutch wear. Some original clutches last well over 100k miles though.
Check the valve cover for oil leaks (hell check the whole car for leaks/unexplained fluids), make sure the alignment is good, make sure the seller ALWAYS used premium gas, basically just do a standard used car check-over.
As for winter, get a set of snow tires and you're good to go. Very few 15" wheels fit, so go with 16" wheels/tires.
Mine: 2008 Saab 9-3 Aero SportCombi XWD: 92k, Black, Manual, JZW Stage 1. 320hp/400tq.
Gone: 2002 SVT, #1654
Hers: 2010 Focus SES: 84k, Ebony, Auto, Moon and Tune
swansong is online now
Old 10-09-2012, 04:26 PM   #5
Ford Fanatic
Fan#: 104637
Ive always been a DIYer so ill probably do that before i put my other car into storage.. Glad i found this information out here rather than the timing belt going and god knows what else!
He told me that the clutch was never changed (original owner) and when driving it, it felt good. Has some chatter coming out of first gear but thats normal for the svtf, correct?
Already got some winter wheels/tires :) think i may powder coat the stock wheels, would look good on a silver car! maybe some tints too.. Ill toss some pictures up either later tonight or tomorrow
Sorry for jacking your thread cassard
Old 10-13-2012, 10:52 AM   #6
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,296, Level 67
Points: 10,296, Level: 67 Points: 10,296, Level: 67 Points: 10,296, Level: 67
Level Up 62% Completed
Forum Activity 18%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (42)
should have no chatter out of first
pasta is offline
Old 10-17-2012, 05:08 PM   #7
GodLovesUgly
.Flat Out.
GodLovesUgly's Avatar
Fan#: 56705
What I Drive: ^^^ That!
Points 28,589, Level 99
Points: 28,589, Level: 99 Points: 28,589, Level: 99 Points: 28,589, Level: 99
Level Up 15% Completed
FF Reputation: 10 GodLovesUgly Great Standing Member
Buy-Sell-Trade Rating: (7)
The clutch master cylinder is something you should check, as they seem to be problematic.
check the clutch pedal for oil-like residue.
also check for coolant leaks dripping onto the front of the transmission. the thermostat housing is known to leak as well.
The Rich Get Richer Until The Poor Get Educated.
Do Vegetarians eat Animal Crackers?
Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics
GodLovesUgly is online now
