Synthetic oils - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2012, 08:16 AM   #11
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
At around $25 for a 5-quart jug of Mobil1, it does seem a little backward to spend $25 on an oil analysis so you can determine whether or not you can save $25 by not buying oil.
And Qweesy, please come out of the 70's and join us here in 2012. Pennzoil conventional is of a completely different forumation than it was when it was causing sludge in your Pontiac Catalina, and Pennzoil synthetics are not even remotely related to their conventional oil in regard to forumation.
Mobil1 ceased to be 'the best' when they downgraded from group IV base stocks to group III. At best, they're now known for being marketing champs for selling highly-refined group III oils as 'true synthetics'.
cbdallas is offline
Old 10-26-2012, 10:56 AM   #12
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
If your intention is to run longer OCI's, you can spend $35 and get a TBN report, and estimate how long you can safely run that oil in your engine before the additives are depleted. If you can do this and extend your OCI by a few thousand miles, it won't take long before you've saved enough money on oil changes to make up the price of the analysis and more. So, there is at least a potential savings.
This is only one benefit among many of UOAs. We're all free to spend our hard-earned dollars as we please, but I feel it's worth our time to learn about the potential benefits of oil analysis before dismissing it as a waste.'
Originally Posted by cbdallas View Post
I've switched to Pennzoil Ultra only because of the lower NOACK numbers.
I've done the same--I just hope Shell isn't lying about the NOACK spec. I will say that consumption has been very low for the past 5K miles I've been running PU.
Hatch Nation #90
TboneZX3 is offline
Old 10-26-2012, 11:23 AM   #13
md2009
Fan#: 93649
What I Drive: 09 S Sedan - Black
FF Reputation: 2 md2009 Good Standing Member
Originally Posted by amc49 View Post
Thank you.
Look at a dictionary for the definition of the word 'value', it means getting something of higher worth for lesser cost. I do not consider oil analysis to be of great 'value' to the common man even though I know what it does. It costs too much to show things that can be logically deduced without the added cost. There are enough facts in books out there to make plenty educated 'guesses', you might say, that will have excellent outcomes in 99.5% of the cases without the need for splitting atoms on the oil. Very close to the arguing that goes onsite here all day long about say 2/10ths of a degree error in computer alignments, quite simply wasted time there too. I can say that having worked on thousands of vehicles including some pretty high output ones and simply never needed to analyze oil. Gotta wonder how the world ever kept spinning without it in the old days don't you?
You say that, but you don't provide a single example of the "guesses" you are going to make.
Are you going to guess on the TBN of your oil after 7500 miles? What if you want to run extended drain intervals? Will you guess what it is at 12000? or 15000? or 20000?
Are you going to guess on the flashpoint of the oil, or determining if you have fuel dilution before major problems start?
Would you guess if there is coolant getting into the oil?
What if you’re leaching other metals? Wouldn't it make sense to catch a failing bearing before the engine starts knocking?
It is unfortunate that you don't use such a valuable tool in your shop. While I only turned wrenches professionally for a short time, the shop I managed used this tool FREQUENTLY. Many major engine manufacturers, including Cat and Cummins, offer this service themselves.
How did the world keep spinning before this technology? Oil was changed too frequently, and money was wasted. Potential problems were missed until the components failed. We used to have exchanged like this on paper and pen.. Would you prefer we went back to sharing information that way, also?
Now, if I were in control of a fleet, maybe, but on a single owner vehicle, no way. I've got Bobtheoilguy for that. Being able to read is a far better value than analyzing oil.
Broad stroke? I submit that since most DON'T do it, it REQUIRES a broad stroke, there's far more of us than of you (those who seem to consider it necessary and of high value).....................
Value?
Here's some. I use conventional oil at 7500 miles oil changes, the last 5 cars I've bought are still running fine, I can't seem to break them. Collectively 850,000+ miles there and not one analysis, no synthetic oil either. If I go under valve covers the motors are clean as a whistle. Someone tell me how much money I've saved to do other things with.........................................that's value jack.
Not 'willfully ignorant', I have just tuned oil analysis out as nice but not necessary in my world. I do take note also that all the OEMs do not require it to maintain warranties either. I'm just taking the same leap of faith they do.
I'm glad that 7500 mile conventional oil changes work for you with your driving style on your vehicles in your climate.
The original question posted was "So whats the story w/ Pennzoil advertising their ultra/ platinum synthetic oil runs cleaner than Mobil 1/ Valvoline synpower/ Castrol edge w/ syntec? Do they have more detergents in their oil over the other's or what?"
You going to tell me that you can GUESS on the answer to this question? Ok. Guess away with your money, but don't recommend it other folks looking for an answer.
It is highly possible that even at 7500 intervals you have wasted a ton of money over the lives of those vehicles. A proper oil analysis could have indicated the ACTUAL oil change interval you should have been using, and may have saved you hundreds (if not thousands) of dollars over the years. That, my friend, is value.
-Mike
md2009 is offline
Old 10-26-2012, 04:39 PM   #14
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
I can easily refute 3/4 of that but I'm tired right now. Simply put, not so in my world, even analysis results in a guess. Completely and totally unnecessary. You will always get some leaching and dilution, impossible not to. No guesswork there.
Save thousands? I don't even spend thousands, I'd be hard pressed to save hundreds. You got me generating cash now. Actually I do, I save drained oil to use for other things, $2.50 a quart you know.............
You guys worry way too much about things that impact you way too little. You'll figure that out in another twenty or thirty years just like I did.
amc49 is offline
Old 10-26-2012, 06:16 PM   #15
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,780, Level 100
Points: 51,780, Level: 100 Points: 51,780, Level: 100 Points: 51,780, Level: 100
Level Up 0% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
Buy-Sell-Trade Rating: (28)
Oil is easy , change it regular , if you change it before its used up then its still cheaper then an engine
If you run the engine hot change it right away
If you race or run the car hard change it a little sooner
Do this and you will be good with any oil you choose synthetic or non synthetic
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 10-26-2012, 11:14 PM   #16
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,910, Level 74
Points: 12,910, Level: 74 Points: 12,910, Level: 74 Points: 12,910, Level: 74
Level Up 15% Completed
Forum Activity 99%
>>>>So it sounds like Mobil 1 isn't that good, huh?<<<<
What is a NOACK spec? So Pennzoil Ultra is the best, say compared to Mobil 1?
felixthecat is online now
Old 10-27-2012, 12:57 AM   #17
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
The NOACK volatility test determines the evaporative loss of engine oil at high temperatures. The lower the NOACK spec, the better, or less evaporative the oil is.
I've switched to Pennzoil Ultra only because of the lower NOACK numbers. 6.4% vs 11% for Mobil1.
Hatch Nation #90
TboneZX3 is offline
Old 10-27-2012, 10:05 AM   #18
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Yeah, I've heard people tend to get lazy in their old age.
Hatch Nation #90
TboneZX3 is offline
Old 10-27-2012, 10:54 AM   #19
Scout706
Fan#: 105129
What I Drive: 2003 Pitch Black ZX5 AT
Points 38, Level 1
Points: 38, Level: 1 Points: 38, Level: 1 Points: 38, Level: 1
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 Scout706 Good Standing Member
I like synthetic oil for peace of mind, don't care what brand.
Scout706 is offline
Old 10-30-2012, 08:53 PM   #20
md11mx
Fan#: 104613
What I Drive: 2009,ice blue,focus
FF Reputation: 1 md11mx Good Standing Member
Just 2 harp in,,,oil anal can be good for identifying individual component wear. change your oil & filters. buy great filters. my oil is always no darker than apple cider. the kind you let you kids drink. i don't change my oil but every 10k or so. and i'm a castrol syn man.
md11mx is offline
