Transmission/Clutch Slipping (OBD2 Plots) - Page 4 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 04-30-2013, 01:46 PM   #31
PratoN
PratoN's Avatar
Fan#: 88058
FF Reputation: 10 PratoN Great Standing Member
Originally Posted by raptor1956 View Post
I think the shudder problem between gears is likely to be bad timing of the handoff between the two clutches.
I agree it's probably a timing thing too (if there is no oil contamination). If it's not software, then it could be a faulty motor or binding components. I don't know if I'll ever get to find out, though.
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at v3.6 89k miles and counting...
PratoN is online now
Old 04-30-2013, 03:22 PM   #32
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
FF Reputation: 46 dyn085 Great Standing Member
Moved to MK3 TSB, Recall & Problems Archive. Also subscribed to see if this helps us net any solutions in the future. My car has random fluctuation of about 250 rpm on steady-state (cruise control, flat surface) driving for what appears to be no reason whatsoever.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 04-30-2013, 03:48 PM   #33
gostinger
Fan#: 44867
What I Drive: 2013 SE Black Pack Loaded 5 Spd MTX
FF Reputation: 1 gostinger Good Standing Member
I am going to chime in on this one only because I believe that the DCT software prior to the latest TSB is better than what DCT owners have now. I think the clutches are engaging while stopped and preparing to move which is causing premature wear and heat. This maybe causing the seals to fail and fluid to leak and the overheated clutches aren't behaving well. The best way to put it is like riding the clutch in a manual. I am not a tech but I recall the roll back we were experiencing prior to this latest TSB was because the clutches were fully released and engaged properly when forward motion was summoned by the accelerator. Again just my 2 cents worth on my experience with my ex-2012 DCT(was like a bad marriage and we got a divorce).
gostinger is offline
Old 04-30-2013, 03:55 PM   #34
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
The TSB that addressed the roll-back uses the brakes to hold the car in place, not the clutches.
September '13 ROTM
2014 FiST-
Old 04-30-2013, 05:15 PM   #35
PratoN
PratoN's Avatar
Fan#: 88058
Originally Posted by gostinger View Post
I am going to chime in on this one only because I believe that the DCT software prior to the latest TSB is better than what DCT owners have now. I think the clutches are engaging while stopped and preparing to move which is causing premature wear and heat... The best way to put it is like riding the clutch in a manual. I am not a tech but I recall the roll back we were experiencing prior to this latest TSB was because the clutches were fully released and engaged properly when forward motion was summoned by the accelerator.
Very plausible. I had issues with my transmission that previous updates seemed to help. 12B37 was great for throttle response initially, but the grinding noises didn't start until 12B37 was applied.
True, but they might hold the brakes as the clutch is engaging which could cause unnecessary wear on the clutch. Not that I think that's the case because I have issues with gears R,2,4, & 6.
Old 04-30-2013, 05:59 PM   #36
gostinger
Fan#: 44867
Yes I know and agree but in my case I could actually feel the car engaging even while stopped before moving forward.
Old 04-30-2013, 06:45 PM   #37
Tubeway Army
Fan#: 111167
What I Drive: 2013 Focus Titanium DCT Dilemma
FF Reputation: 1 Tubeway Army Good Standing Member
I did a first time aggressive launch today when I pulled out in front of oncoming traffic, enough to squeal the tires. The transmission did not grind and I had it in D mode as it cycled through the gears at high RPM.
To me at least in my case, there seems to be a correlation between high RPMs and limited slippage, maybe the clutch is engaging faster and not dragging it's feet thinking of what gear to be in?
Tubeway Army is offline
Old 05-11-2013, 11:02 AM   #38
fordman46
Fan#: 96770
What I Drive: 2012 Ingot Silver Focus Titanium
FF Reputation: 1 fordman46 Good Standing Member
Originally Posted by FordCustomerService View Post
Hi everyone,
Remember that I'm here to help; if your vehicle is exhibiting transmission/clutch slipping, I want to see how I can help. Please send me a PM with some background on what you've been experiencing, your VIN, dealer, mileage, and a good daytime contact number. I'll start researching.
Thanks!
Crystal
VECHILE: 2012 Ford Focus Titanium
MILEAGE: 6,590
12B37 update
I first experienced slipping around 3,546 miles when shifting from 1st to 2nd, especially in high-torque situations like going up a hill from a dead-stop. The dealer looked for leaks, checked pressures, drove the car, and "found nothing". This seemed to level off and I have been dealing with it.
The car has to be driven for a while before the slipping occurs. I recently drove the car about 650 miles in one day, with only food and gas stops. Once I reached my location and drove in the city, stopping at stop-signs and accelerating, it was slipping excessively. I was at that location for 3-days and it slipped throughout after running about 10-miles. Once I returned (another 650 miles), the car sat in the garage for 3-days without use. I drove about 10 miles on the 4th day and for miles 1-9 it was perfect. About 10-miles, it started slipping again when I accelerated. It's mainly from 1st to 2nd. The slipping after 10 miles was not as bad as the reaction after driving 650 miles in one day.
The car is going to the dealer on Monday for a Sync update, since it doesn't upgrade from my flash drives. I plan on driving it for a while so the service writer can take a drive with me and see what it is doing.
Here is an update on this post. The dealer performed the tests on the transmission and it failed so they are ordering a new clutch for it. I guess there is a backlog on getting these clutch's.
on the Sync issue the dealer could not update my system and they had to order a control module.
fordman46 is offline
Old 05-14-2013, 04:16 PM   #39
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Originally Posted by fordman46 View Post
VECHILE: 2012 Ford Focus Titanium...
Hi fordman46,
I recommend editing your post to remove your private information from appearing publicly. I'll reach out to you via private message with your case information.
Thanks!
Crystal
FORD SERVICE
p: 800.392.FORD
f: facebook.com/FordFocus facebook.com/Ford
FordService is online now
