02 Focus DOHC Hot Start - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-14-2012, 04:48 PM   #11
223splatfactor
Fan#: 104570
What I Drive: 2002 Silver ZX3
FF Reputation: 1 223splatfactor Good Standing Member
Yes, I'm a former electrictian, and I always shoot the ground first.
It just failed about an hour ago, fuel pump frimes-dash light do the self check.....and nothing. Wife is stuck at Walmart, her team is playing right now, and she is NOT happy !! Me either!!!!! Neil
223splatfactor is offline
Old 10-14-2012, 05:18 PM   #12
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Um, I know it's crude, but have you considered giving the starter a gentle nudge with a rubber mallet? (I'd put it in gear and bump start it if it were a MTX to isolate the starter motor as the problem.)
BC_ZX3 is offline
Old 10-14-2012, 05:53 PM   #13
223splatfactor
Fan#: 104570
It's an AT-I don"t think there is room for a hammer !!!!!!!
Old 10-14-2012, 06:13 PM   #14
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
I've seen the ignition switch do this, but I usually expect other problems associated with a bad ignition switch. I'd hate for you to replace it, and that not be the problem.
I'm sort of miffed by the starter relay having burnt looking pins too. All that relay should do is provide a way for the PATS and NS switch to prevent the car from starting. The inertia switch cuts off the fuel pump, so it's obviously working. The starter relay breaks the hot going to the solenoid (the real starter power relay) so that the car won't start either in gear or without the transponder signal from the RFID chip in the key.
Is there anywhere in your area that rebuilds starters? Look in the YP and see if you can find a local rebuilder, either that or ask at local shops. That's who uses those, and what keeps that business in business. Most of the time a local rebuilder will rebuild your starter or alternator cheaper than you can purchase one at a parts store. The work is typically more reliable too because returns are more damaging to small businesses. We've found that local alternator rebuilds are much more reliable.
An old man somewhere in the back of my mind is telling me that an engine that won't start hot has a problem with the starter solenoid.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-14-2012, 06:21 PM   #15
223splatfactor
Fan#: 104570
Why, That looks like the narrowed field is. Logic monster says the back side of the engine isn"t thta hot. But.....If it is the original starter, it has had some cycles on it.
I looked at the removal, and I hate to think what my not so small hands will look like after this excercise.
Old 10-29-2012, 07:13 PM   #16
223splatfactor
Fan#: 104570
UPDATE Put a new relay in.....NOT
Put a new starter switch in.... NOT! Crap have to pull the starter....
Several hours later..and parts store gave me the WRONG starter.
More bleeding from my hands and arms. Correct starter..works!
After a week of driving the problem is resolved.
Thanks to all who replied-Neil
Old 10-30-2012, 05:57 AM   #17
Mitch1989
Mitch1989's Avatar
Fan#: 105151
What I Drive: 2001 Zx3
FF Reputation: 3 Mitch1989 Good Standing Member
Glad you figured it out. I'll keep your issues in mind in case they happen to me! :)
Mitch1989 is offline
