Engine mounts - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > DURATEC Performance (2003-2007)
Old 10-06-2012, 07:35 PM   #1
luv2ridemx
Fan#: 104339
What I Drive: 2007, grey, focus se
FF Reputation: 1 luv2ridemx Good Standing Member
Engine mounts
I just bought a 4 door, 2007 ford focus SE / US model 2.0 eng. 68,000 miles.
can someone please tell me why i keep reading about people replacing the engine mounts ?? my eng does shake a lot, and what to look for if so... is that why ??
thank you
Derek
luv2ridemx is offline
Old 10-07-2012, 02:37 PM   #2
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 52 felixthecat Great Standing Member
thank you
Derek
1st off to FF. When you say shakes a lot, What do you mean? Does your motor run good? Has a miss or something? If you can find another 20 Focus & compare that motor at idle. If you can open the hood & pre load the atx or let the clutch out some & see if the motor is rolling around or not. Maybe someone can help you w/ this.
Introduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 10-08-2012, 12:34 PM   #3
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007 Focus
FF Reputation: 4 VEGAS Good Standing Member
front wheel drive motors twist hard under abuse and rip the dry rubber, fresh mounts last 4 to 6 years normally. Common one breaking is passenger and lower tranny, upper tranny may go out but is not really a issue on how it sits. if the lower bone goes you will hear a bump under the hood when you have acceleration from a stop, and hit reverse. the Passenger mount will vibrate almost all of the time.
VEGAS is offline
Old 10-08-2012, 10:11 PM   #4
luv2ridemx
Fan#: 104339
Ok, thanks. I do have a automatic to its probably more prone to the stick shifts.
Old 10-14-2012, 08:26 PM   #5
felixthecat
Fan#: 80663
More so if you have your foot on the brake & shift from drive to reverse or vice verse. Then you can see the motor roll around w/ the hood open. I'd upgrade to a vf engineering dogbone.
Old 11-08-2012, 02:44 AM   #6
karmakc
karmakc's Avatar
Fan#: 78622
What I Drive: 2004 Ag ZX3 D23E MTX
FF Reputation: 1 karmakc Good Standing Member
Hey Felix,
I got the CFM dogbone about a year ago...and I've noticed a few things.
The vibration at around 800-900 rpms is normal for the dogbone, I get that. However, with the A/C on I get a lot of vibration at lower engine speeds too...I never torqued the bolt but did a wrench twist and tightened it up without overloading it...
Any suggestions?
Hatch Nation #135
Blazin' the Twisties #90
karmakc is online now
Old 11-08-2012, 06:06 AM   #7
felixthecat
Fan#: 80663
Originally Posted by karmakc View Post
Hey Felix,
Any suggestions?
I'd tighten the to bolts to 35lbs. W/ the a/c on your going to have the fans kick on, maybe thats your vibration.
