Car seems faster with ethanol - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 10-06-2012, 03:50 PM   #1
huxrules
Fan#: 104576
What I Drive: 2012 Titanium
FF Reputation: 1 huxrules Good Standing Member
I recently tried some E85 in my car. Just because I can. The focus now seems faster which I didn't think was possible with ethanol. Is the engine capable of changing the timing due to ethanol's higher octane? The milage has gone down but if I can easily get more performance I'll do it. Anyone notice a change with ethanol?
huxrules is offline
Old 10-06-2012, 03:54 PM   #2
lyonsroar
Guest
Fan#: 63166
What I Drive: 2009 Volkswagen GTI
FF Reputation: 31 lyonsroar Great Standing Member
http://health.howstuffworks.com/medi...ebo-effect.htm
lyonsroar is offline
Old 10-06-2012, 04:45 PM   #3
GMconvert
GMconvert's Avatar
Fan#: 101277
What I Drive: 2010 Sangria Red Metallic Focus SES
Points 252, Level 5
Points: 252, Level: 5 Points: 252, Level: 5 Points: 252, Level: 5
Level Up 4% Completed
FF Reputation: 2 GMconvert Good Standing Member
FI guys do quite well with E85, at least the S/C and turbo Buick crowd does. It burns at a lower temperature than gasoline and some have compared it to a small intercooler. They have also upgraded all fuel system components (pump/lines/injectors if needed) and have tuned for the different AFR of ethanol.
Putting ethanol in any gas engine that's not tuned or designed for it usually results in lower mileage and less power. When E85 was whole dollars cheaper than gas, it made sense because the cost offset made up for using more E85 for the same amount of miles that gas would give you. Now that it's within a few coins, it's not worth it.
And yes, all modern cars will alter timing based on air temp, fuel octane, etc. to a certain extent, but there are still parameters outside of which it can't extend. Unless you specifically tune for it, it's best to use what the manufacturer calls for. On my '00 Blazer, I actually get more miles out of 89 than 87 - enough where it's actually cheaper to use 89. My S/C Regal required 93 so that's what it got. There was definitely a drop in power if you used anything lower because the PCM pulled timing to safeguard the engine from the lower octane. The '10 Focus sees no advantage in mileage (which is why I bought the car) for anything above 87 over the course of dozens of tanks of each grade, so it gets 87.
CLIFFor Sale: In non-forced induction cars, ethanol and ethanol blends generally result in less mileage but not necessarily better performance, unless you're specifically tuned for it.
I'd wager that the new ST would do better on E85 than gas once it's tuned due to the turbo.
GMconvert is offline
Old 10-06-2012, 05:36 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
The fuel system is not designed for it. I know people who have tried it and had problems. DiscipleRocks is one FF who has been running E85 for a long time IIRC.
Newer engine software might contain an algorithm to advance spark to the point of knock, and then back off X deg. It might test for this regularly to keep the most advance. It would be nice to know for sure, but that would explain your power bonus. Of course, the new Focus has compression ratios closer to what works best for E85 anyway.
I personally would like to see more interest in isobutanol myself. It reduces hydrocarbons more than E does, and doesn't cause fuel separation. Maybe in the next 10 years or so. Right now, it's an emerging tech, but E plants could be converted, and we wouldn't be 100% reliant on corn for fuel additives.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-06-2012, 06:51 PM   #5
mjd4277
King of all blacks!!
mjd4277's Avatar
Fan#: 64900
What I Drive: 2013 Fusion SE,2012 Fiat 500 Abarth
FF Reputation: 7 mjd4277 Good Standing Member
Agreed. It's clearly marked on the gas cap of my 2010 that gasoline with E80-E85 is a no-no.
1975 MG MGB Mk IV "Downshift"
2012 Fiat 500 Abarth "Scorpion"
2013 Fusion SE "Epyon"
2003 Nissan Frontier SVE "Trailbreaker"
Team Duratec #241-Bailout Money?!?! WTF is that??
mjd4277 is offline
Old 10-06-2012, 10:57 PM   #6
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
Add stickers, that will make it faster.
GreySkorpion is offline
Old 10-07-2012, 04:33 AM   #7
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2014 Tuxedo Black SE Sport
Points 1,604, Level 23
Points: 1,604, Level: 23 Points: 1,604, Level: 23 Points: 1,604, Level: 23
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
FF Reputation: 5 StingRay Good Standing Member
I'm not sure on the 2012's but my '13 is flex fuel capable, so yes the fuel system is designed for it. The new computer system on the MK3 is supposed to be able to adapt to any amount of ethanol content and change the tune to achieve optimal AFRs, or at least that's what I've read. Technically the car could add more timing and therefore make a tad bit more power, but I'd have to see a dyno sheet that proves it's making more power because I wouldn't think the factory ECU has performance in mind when it changes the tune.
StingRay is offline
Old 10-07-2012, 06:09 AM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,689, Level 86
Points: 18,689, Level: 86 Points: 18,689, Level: 86 Points: 18,689, Level: 86
Level Up 68% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
Hearsay and conjecture.
The fuel system wasn't designed specifically for Ethanol. That does not mean it's not compatible with it.
People will say 'you'll run lean and blow up your engine'. Though the possibility is there, the odds are low. As far as the fueling is concerned, nothing in the system knows what type of fuel you're using. All it knows is that it's shooting for ~0.5v average during closed loop and a preset Short Term Fuel Trim during open loop. Providing the injectors can supply enough fuel, these presets will be hit even on E-85.
The Flex Fuel vehicles have an added Ethanol content sensor that measures the specific gravity of the fuel. Ignition timing is adjusted according to Ethanol content.
Yes more power can be made on Ethanol than pump gas. But it is also correct to say that the majority of the time this will not be the case unless you can adjust the ignition timing to take advantage of the added Octane.
Best advise I can offer is that if you wish to try it, please do so safely and know the risks going in. It would also be a good idea to be able to view live data; that way you have a little warning if something isn't going well.
OH, you're not playing dumb ...
iminhell is offline
Old 10-07-2012, 12:12 PM   #9
huxrules
Fan#: 104576
The focus in question is a 2012 and is a flex fuel version.
huxrules is offline
Old 10-07-2012, 12:23 PM   #10
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Then it would be nice to know power output, fuel consumption, and $/mile comparison. It would be nice to know if it works great if you have E85 readily available. In my market, it's not so easy to find.
There have been some advances in fuels and energy in the past 4 years or so that we're going to see the benefit from in a few years. So much of alternative energy options are in their toddler stages- slightly past infancy. I'm curious to see what happens in the next few months. The battle between fossil fuel advocates and future tech rages on.
Be eclectic.
