2002 zts 5-speed will only go in reverse when engine is off????? Help?! Please. - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 10-06-2012, 02:45 PM   #1
Phillabust
Fan#: 104574
What I Drive: 2002 Gray ZTS
FF Reputation: 1 Phillabust Good Standing Member
It started about a month ago... I turned on my car, and when I put it into reverse it took a lot of struggle, but I eventually got it in there. Then every day after that, it just got worse and worse and now it's impossible to get it into reverse when the car is on. I end up turning the engine off, putting it in reverse, then turning it back on just to get out of my driveway. That, or jumping out, pushing it, and jumping back in. A few weeks ago it would get better as the day went on, and after about a half hour of driving I could force it into reverse again, but now it won't work at all. Even after I've been driving it all day. And now 1st gear is doing the same thing.... it's a struggle to get it into 1st with the engine on. And it's getting worse, so pretty soon it wont go into 1st at all.
I don't know much about cars, I'm only 17. But if anyone has any advice, that would be splendid. Thanks.
Phillabust is offline
Old 10-06-2012, 02:53 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,441, Level 94
Points: 23,441, Level: 94 Points: 23,441, Level: 94 Points: 23,441, Level: 94
Level Up 10% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
does it try to grind if you put the clutch in and move it? I know the feeling though... have seen that with a few Subarus though it should be the same for any gear.
normally I might say clutch, but I believe its trouble with your shift linkage. a bushing is probably loose or missing.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 10-06-2012, 02:58 PM   #3
Phillabust
Fan#: 104574
It doesn't really grind when I put the clutch in and move it. Just today and yesterday, when I put it into 1st, it would feel like it's in the gear, so I'd let go of the stick... then it would pop out and make a grinding noise. All the gears are stiff.....
Old 10-06-2012, 03:18 PM   #4
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,115, Level 55
Points: 7,115, Level: 55 Points: 7,115, Level: 55 Points: 7,115, Level: 55
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 4 matmatician Good Standing Member
My bet would be the linkage. I had some linkage disconnect while I was driving and the only gear I could get the car into was 2nd. That's where I would start.
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 10-06-2012, 03:29 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
Points 27,353, Level 98
Points: 27,353, Level: 98 Points: 27,353, Level: 98 Points: 27,353, Level: 98
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
Try this, engine off, no clutch, shift into each gear before you start the car. I used to have to do this to "loosen up" one of my old vehicles. I'd go 12345R54321N before I even pushed the clutch down to start it. It would loosen up considerably after a short distance of driving.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 10-06-2012, 03:52 PM   #6
Phillabust
Fan#: 104574
Could it have anything to do with not changing my transmission fluid?? Because its been at least 20000 miles since its been even checked.
Old 10-06-2012, 05:20 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 17%
Well, that would certainly help. I highly recommend Ford's fluid. Just go to a dealer and tell them what transmission you have, and get 2 quarts. There is a How-To on this site for changing MTX fluid, check the link in my signature.
Be eclectic.
Old 10-07-2012, 06:56 AM   #8
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 454, Level 9
Points: 454, Level: 9 Points: 454, Level: 9 Points: 454, Level: 9
Level Up 8% Completed
FF Reputation: 17 nilskje Great Standing Member
If it works fine with engine off, its most likely the clutch not disengaging properly,or the pilot bearing dry, making the input shaft rotate a little, most commonly seen on IB-5 gearboxes (the one without a drain plug), It has no syncro on reverse, unlike the MTX-75.
Try putting in 1 gear and then take it to reverse, keeping the clutch pressed. Mine has been like that for a long time..
nilskje is offline
Old 10-07-2012, 10:07 AM   #9
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 17%
OH snap!
What engine do you have? That will tell us what transmission you have. Do you know how to identify the different engines? Very easy: If it says Zetec on the valve cover, then the MTX75 is what you have. If it says Split Port Injection, then you have the IB5 transmission.
Be eclectic.
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
