Valve cover gasket - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-05-2012, 07:54 AM   #1
kevin37
Fan#: 104518
What I Drive: 2002 SE Wagon Green
FF Reputation: 1 kevin37 Good Standing Member
Valve cover gasket
I have a small oil leak coming from under the valve cover next to the timing belt. I plan on replacing the gasket and just want to see if anyone else has had this problem and make sure that it is just the gasket. Any info is greatly appreciated. Oh and it's a zetec
kevin37 is offline
Old 10-05-2012, 07:22 PM   #2
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,168, Level 41
Points: 4,168, Level: 41 Points: 4,168, Level: 41 Points: 4,168, Level: 41
Level Up 9% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
You brakeklean the leak and see we're its coming from.
I now drive a Japanese Ford.
macdiesel is offline
Old 10-06-2012, 12:52 AM   #3
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
Yep, could be a cam seal too.
amc49 is offline
Old 10-09-2012, 04:52 PM   #4
oshoguno
Fan#: 45853
What I Drive: 2012 Focus SE Hatchback
Points 652, Level 13
Points: 652, Level: 13 Points: 652, Level: 13 Points: 652, Level: 13
Level Up 4% Completed
FF Reputation: 1 oshoguno Good Standing Member
The valve cover gasket leaks quite often, mostly near the front of the engine. It is pretty straight forward to replace, just make sure to clean the engine first so that no gunk from around the cover can fall into the head when you pull the cover off. There are threads about it, just do a search and you will find them.
oshoguno is offline
Old 10-09-2012, 07:52 PM   #5
amc49
Fan#: 96610
Forum Activity 3%
The bolts are shouldered, meaning they hit solid at the last. If it leaks then you get to do it all over, you absolutely cannot over tighten bolt to stop leak since the gasket can get no tighter once you have bottomed the bolt. The bolts are not really hardened, you will break them like so many others here do then fun city. Simple job turns into nightmare...........
Clean and dry and it'll work flawlessly, get sloppy and leave some crap in cover groove and you probably get to do it over. No need for any sealant except maybe a small dab right in the corners of cam caps. Tighten all bolts evenly, the gasket is thick and can roll the sealing edge over to not seal if you tighten a whole bunch in one spot without rest of the cover coming down with that spot evenly. Look at gasket close too, I've seen pieces of mold flashing that could interfere with sealing. I peel them off.
amc49 is offline
Old 03-22-2013, 10:57 PM   #6
logsdon
Fan#: 111960
What I Drive: 2003 Red ZX5
FF Reputation: 1 logsdon Good Standing Member
Check engine light comes on, engine runs rough
I unhooked the breather tube from the valve cover, unhooked spark plugs covers, took out valve cover bolts, but had an issue with one at the bottom middle above the heat shield... there is a part of the shield that is on top of that bolt (like an upside down 10mm bolt attached to the valve cover bolt below it) and I couldn't get it off.
I'm a novice, chickened out, put the bolts back on, spark plug covers back on, breather tube back on... the car runs/idles awful and the check engine light came on.
Any thoughts? Bolts are on gently, maybe not enough torque (no torque wrench). Maybe I don't have a spark plug cover on completely?
logsdon is offline
Old 03-23-2013, 12:31 AM   #7
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
x2 on the cam seals, that happened to me.
don627 is offline
Old 03-23-2013, 12:46 AM   #8
logsdon
Fan#: 111960
Thank you. If I'm understanding correctly I need to make sure the valve cover bolts are on snug (not too tight as I've seen described in other forum posts) to ensure the seal and will give that a shot. If that doesn't do it I'll have it towed to a shop vs. driving it there to complete the job.
logsdon is offline
Old 03-24-2013, 03:39 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,721, Level 73
Points: 12,721, Level: 73 Points: 12,721, Level: 73 Points: 12,721, Level: 73
Level Up 68% Completed
Forum Activity 99%
Plug connections in the wrong order or loose, that's all that's likely from what you did. Re-check it & you should be OK. Chk. engine light would come on from the misfire, no worries there once corrected.
Luck!
sailor is online now
Old 03-24-2013, 04:25 PM   #10
logsdon
Fan#: 111960
Thank you. I think you are right about having been loose. I ended up having it towed just so I didn't make anything worse in driving it there since I couldn't finish the job myself anyway. Besides the gasket, they checked spark plugs (they must have caught the misfire in the check engine light) and found a large gap on one that may have contributed to misfiring so I'll look at it as a blessing in disguise that it got discovered in addition.
logsdon is offline
