Holset hx35 good turbo? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-06-2012, 02:22 AM   #21
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Thanks for the tip do u know the size of the vband
Originally Posted by StockTalon View Post
Welcome to a stock Holset.
Tip, if youre going Holset vband, buy a new one for a Holset or, get one with the downpipe/vband clamp. It is not a standard Vband.
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 10-06-2012, 06:17 AM   #22
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
i know you can pick up teh elbow on ebay and its a stock dodge piece. that bolts to a two bolt flange after that. and that elbow is around 30 bucks i think...
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 10-06-2012, 11:48 AM   #23
StockTalon
Guest
Fan#: 94771
What I Drive: 2012 Focus Titanium
FF Reputation: 1 StockTalon Good Standing Member
You will need to get one from Holset/from a store for a Holset. The diameters are the same as every other v band out there but, the flange itself is different. Ive read that its the same one one you will find on a Borg and some PTEs but, I cant say that is true. I just bought a new one from a company who sells aftermarket parts for trucks.
StockTalon is offline
Old 10-06-2012, 12:52 PM   #24
koke'sfocus
Fan#: 69779
Ok I'm not worried cause the one I think I'm gonna buy it has the 5 bolt to vband but my original down pipe flange design is a 5 bolt oh and is a 7blade :) if some one need more info of the holset turbos heres a link to dsmtuners that has a lot of info
http://www.dsmtuners.com/forums/newb...essor-map.html
team duratec #94
D23 crew #9.
Old 10-06-2012, 02:27 PM   #25
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
got a buddy in town here who works on turbo's all day rebuilding them. for me its a matter of packaging space. if we can get it in there cose enough to the block i may be good to run
Paladin is offline
Old 10-06-2012, 02:35 PM   #26
StockTalon
Guest
Fan#: 94771
The HX35 and even the HX40, is a very small turbo, space shouldn't be an issue.
Old 10-06-2012, 06:04 PM   #27
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
mmkay. got an idea on inches wide? havent gotten to see one in person yet.
Paladin is offline
Old 10-07-2012, 12:20 PM   #28
StockTalon
Guest
Fan#: 94771
This is an HX40, divided T3 16cm2 housing.
Hopefully that gives you an idea of the size of a HX40 which, will help make these make sense.
Left is a HX30 the middle is the HX35 and the right is a HX40.
Old 10-07-2012, 04:18 PM   #29
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
ok so a bit smaller than a liscense plate and about just as wide. from what ive seen the v band is a 3" i ahve however foudn the exhaust elbow on ebay for about 70 bucks if i need to use it.
Paladin is offline
Old 10-07-2012, 04:21 PM   #30
StockTalon
Guest
Fan#: 94771
I wouldn't get the elbow, you want as much straight pipe out of the turbine housing as possible. The general rule is, 30 diameters before the first bend. Now, we all know that isn't possible but, you still want to get as close to that as you can.
