Holset hx35 good turbo? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-05-2012, 04:40 AM   #1
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Ok I saw one on craigslist for cheap I been looking for some info on this turbo it seems really good my only Qs? Is it would spool fast? How much hp could I get from one of this stock bottom end @ 12psi? Any input it would be apretiated
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 10-05-2012, 04:05 PM   #2
koke'sfocus
Fan#: 69779
Some one?
team duratec #94
D23 crew #9.
Old 10-05-2012, 05:08 PM   #3
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
nobody on these forums has ever used one. Some have talked, and thats as far as it has gotten....
my guess due to its size and journal bearing status, it wouldnt spool quickly
BigRed03 is offline
Old 10-05-2012, 05:34 PM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
From other posts about this I read it really would be like adding a snail to your Focus
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 10-05-2012, 06:23 PM   #5
StockTalon
Guest
Fan#: 94771
What I Drive: 2012 Focus Titanium
FF Reputation: 1 StockTalon Good Standing Member
They actually spool very quickly on a gas engine. For more info, read here:
http://www.dsmtuners.com/forums/turb...urbos-faq.html
I currently run a divided T3 HX40 Pro and expect to see full boost around 4k.
StockTalon is offline
Old 10-05-2012, 07:26 PM   #6
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
yes, i know DSMs love these turbos, but the zetec engine (where most of my knowledge resides) flows nowhere near as well, hence the longer spool i quoted. A duratec engine might be different.
BigRed03 is offline
Old 10-05-2012, 07:31 PM   #7
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
^^ if a 1.8 t golf can spool it so can we. and most turbo's we end up seeing are journal bearing. unless otherwise specified.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 10-05-2012, 07:33 PM   #8
StockTalon
Guest
Fan#: 94771
They don't flow as well as you think they do.
But, the fact that a Holset is designed to work with colder, less dense and, slower moving exhaust gases allow them to spool much faster than a standard turbo. The best bet for the car in question is probably a DSM bolt on housing since, its a .55 a/r. Its small enough to come up fast yet, large enough to reach the flow potential of the compressor wheel.
A divided T3 would come up just as quick if not faster with the correct manifold. With a manifold that is designed properly, it not only would make more power down low and in the mid range but, come up even faster than the .55 a/r housing.
Another good thing to go with the turbo is, adjustable cam gears so, you can force the turbo to come up even sooner.
Also, remember that either motor has higher compression which, would help spool and make power easier.
Old 10-05-2012, 08:10 PM   #9
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
from pricing things on ebay. you can have a holset with a remanufactured center section oil cooled only, for about 500 bones if not less.
i ahve been looking at these for my svtf, and i think it would work better than people think. after all they are built for diesel trucks which dont spin very high.
Paladin is offline
Old 10-05-2012, 08:12 PM   #10
koke'sfocus
Fan#: 69779
^^^^ yeah I been looking on dsm tuners that It spool like 3500ish on the 2.0s mine is a 2.3 so it will spool faster and I look also that it flows 52lb/min so it dOes flows like a 50 trim or 20g
team duratec #94
D23 crew #9.
