Originally Posted by svth8er
I took the car to have the clutch looked at n then they bled the brakes n clutch n it is still is slow to catch at times when u let off the gas and then get back on it.. they said the clutch is ok ,,,i just dont understand ..what could it be its like its slow but not slipping ..It does it more if i go around a sharp corner it seems worse ,,is there anyway it could have somethin to do have a bad motor mount???I used after market upper right n lower trans mounts could it be cause of that got ford ones comin tommorow????
I'd replace the mounts w/ vf engineering ones. Is your clutch slipping in a high gear= like 40mph in 4th gear & gas it, does it go or does the engine rev? Is the clutch pedal feel soft? I'd check your slave cylinder for leaks.
