Air Filters - Performance vs Restriction - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 11-11-2003, 03:34 PM   #1
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
There have been some debates on this forum about certain air filters being better than others performance wise.
Well, I have some questions.
1.
If an air filter is less restrictive( by means of larger holes in the filter or less filtering material) and allows more air, doesn't this defeat the purpose of the air filter(to remove dirt and contaminets BEFORE it reaches the engine) ?
2.
Seems that some people prefer less retrictive air filters because they are better/less retrictive and give you more air for performance but for everyday driving, can't this be bad since U are allowing more dirt and contaminets in to the engine that would normally be filtered out by a more restrictive air filter ?
3.
In the long run, aren't U just killing/damaging your engine quicker by allowing more dirt and contaminets in to your engine when you use a high-flow/less retrictive air filter ?
Just reading.....
microtonal is offline
Old 11-11-2003, 03:36 PM   #2
GaryFocus
Fan#: 1265
FF Reputation: 1 GaryFocus Good Standing Member
Seems like questions you should be asking k&n or fram...
GaryFocus is offline
Old 11-11-2003, 03:55 PM   #3
RPIJG
Mr. Wizard
RPIJG's Avatar
Fan#: 18
What I Drive: '02 Focus SE 4DR Zetec
FF Reputation: 1 RPIJG Good Standing Member
In theory you are correct, but you make one major assumption, that the less restriction means less clean air.
Most air filters that come in a car, are made of some sort of foam or fiber material close to it, perhaps a cotton material.
However, several manufacturers make air filters with different materials, and use oils and other treatments to do so. It isn't so much that just the air pass more freely but that it remains as clean or better than the filter prior to it also.
Bye Bye Focus
Hello MkV GTI w/DSG!
RPIJG is offline
Old 11-11-2003, 04:06 PM   #4
GonFishin
Fan#: 262
What I Drive: 2000 ZX3 / 2006 Mustang GT
FF Reputation: 1 GonFishin Good Standing Member
It's different filtration and not simply a more porous filter element. A stock filter is basically paper or tightly woven fibers which uses the size of the "pores" (or gaps between the fibers) to block particles above a certain micron in size. Most aftermarket filters are foam filters which do have larger "pores" for airflow, but utilize an oil mixture to stick passing particles to the filter instead of just blocking large particles. The more particles of debris that the foam filter picks up closes the "pores" and actually increases filtration. Since the foam filter relies on the sticky oil instead of the size of the "pores", it actually catches particles smaller than a stock filter while maintaining higher airflow.
Obviously both filters have their own negative aspects.
1) neither can catch all particles
2) foam filter can dry out and lose filtration ability but a recharge kit will solve this
3) a stock filter cannot be cleaned and re-used so once it's clogged, it's time to get a new one which could be after a week of use if you drive down a lot of dusty roads
4) a foam filter fades in color when it's time to "recharge"
5) a stock filter does not have any indication of when it's dirty and when you finally can see it's dirty, it's probably been "replacable" for a long time
6) etc.
7) etc.
8) etc.....I agree, you should go to the K&N website for more info if you want it...
2000 ZX3 / Stage 1 + Gears / Intake / Exhaust / Tune
128whp @ 5000rpm and 135wtq @ 3800rpm
2006 Mustang GT / Intake / Exhaust / Tune
roughly 290rwhp & 315rwtq
GonFishin is offline
Old 11-11-2003, 04:08 PM   #5
hendu33
Fan#: 659
What I Drive: 2000 Focus SE/Zetec
FF Reputation: 1 hendu33 Good Standing Member
http://www.bobistheoilguy.com/airfilter/airtest1.htm for more info. than you want to read about for air filters.
hendu33 is offline
Old 11-11-2003, 06:08 PM   #6
mofocus
mefocuslongtime
mofocus's Avatar
Fan#: 5
What I Drive: Beltfed,extra pullified,weeemachine
FF Reputation: 6 mofocus Good Standing Member
Buy-Sell-Trade Rating: (17)
eh there are some decent info on focussport under the itg panel filter, although i wouldnt doubt if some of it is slightly biased
MAY 2007 ROTM WOOT [/COLOR][/B][/U]
my dyno video
mofocus is offline
Old 11-11-2003, 10:21 PM   #7
eggyolk
Fan#: 1298
What I Drive: 03' ZX3 2.3
FF Reputation: 1 eggyolk Good Standing Member
Stock air cleaners are not necessarily restrictive because of the FILTER they are using, some have noise dampeners that restrict air flow.
03' EggYolk Yellow ZX3 2.3 Duratec
Eibach Pro-Kit springs
FocusSport Cool-Flo Intake/FocusSport Exhaust
Draxas race header
eggyolk is offline
Old 11-12-2003, 08:19 AM   #8
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I use K&N on everything I own, when you go to any type of racing event, be it cars boats, motorcycles , whatever, all you see are k&n's or one of the many knock off brands that also work fine..the k&n reps will actually tell you that their filters work better the dirtier they get ( to a pooint)...I'm not trying to rag on anyone, but this is one of the greatest things on the web that is argued to death with perhaps as much as 90 % of the info out there being all bad...The foam filters are also okay but I prefer the K&N for a few small advantages, and I've seen 20 year old k&n's you could still use, the foam begins to degrade before that.
Run the K&n and don't worry several million of us are just fine with them .
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 11-12-2003, 01:46 PM   #9
GonFishin
Fan#: 262
they've (K&N) got a million mile warranty right? As long as you don't tear the filter (and saying it's the same size), you can transfer it to your next car and just buy a recharge kit. A million miles for most drivers would be like 50 years of driving (I doubt it really lasts that long though).
Old 11-12-2003, 01:53 PM   #10
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
Some people have said that a cone filter is better flowing than a K&N panel filter.
For arguments sake, what if the cone filter and K&N panel filter have the same cfm rating, will this still be true or will both be equal ?
Just reading.....
Similar Threads
Easy Street Air Bag System *SOLD* LosThopeX23 Archive 7 03-14-2006 04:57 PM
Do we want the new Purolator Pureone Air Filter for the Focus? Jibberish18 Ford Focus & General Car Chat 12 01-15-2006 10:50 PM
air filter question cjmartinyZX3 ZETEC Performance (2000-2004) 9 02-08-2005 08:47 AM
For Sale: AEM Cold Air Intake W/ Air bypass valve. ZeeXthree Archive 2 11-12-2004 02:23 PM
For Sale: Universal Air Filters XLINTEL Archive 5 09-07-2004 03:39 PM
