Think I figured out the shuddering when starting from a stop...can't believe it - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-03-2012, 01:03 PM   #21
kjl2012
Fan#: 97883
What I Drive: 2012 se black
Points 81, Level 1
Points: 81, Level: 1 Points: 81, Level: 1 Points: 81, Level: 1
Level Up 62% Completed
FF Reputation: 1 kjl2012 Good Standing Member
It dose indeed work no shudder.
kjl2012 is offline
Old 10-03-2012, 01:11 PM   #22
Kabigon
Fan#: 88299
Points 4,575, Level 43
Points: 4,575, Level: 43 Points: 4,575, Level: 43 Points: 4,575, Level: 43
Level Up 13% Completed
Forum Activity 13%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by cobie56 View Post
i agree.. major flaw in engineering this feature.....
Do you know of any recent cars that don't have this "major flaw in engineering"?
Kabigon is offline
Old 10-03-2012, 01:14 PM   #23
pozi240
Fan#: 94835
What I Drive: 2012 Focus 5 door SEL Kona Blue
FF Reputation: 4 pozi240 Good Standing Member
hotleadsingerguy, you're a genius! Inconclusive for now (I have a long commute home later today to gather more "data"), but, I went out mid day for errands, and tried this (I have the shudder issue as well), and , it worked! Not a single shudder, stumble or hesitation at all. Very smooth starts from a standstill, and the shifts seemed "crisper" for sure. Just before I re parked the car for the day, I turned the TCS back on just to test this, and my last standing start into the parking lot produced the shudder right away...hmmmm, I think we may be onto something. I have the car booked in tomorrow for an oil change and they are looking into my DCT issues (may have a leaking seal inside the bell housing). I will mention this finding to them to see what they think.
What I find surprising (I guess maybe I shouldn't though), is how come none of the service guys or Ford engineers even once thought about this, since we all know that the latest TSB/FSA update changed the way the TCS/ABS system behaves ---- none of these field engineers looked into a possible connection? really??
Like you hotleadsingerguy, my shudder issues didn't start until after I had the last update applied (not by choice, the dealer did it anway)... it drove fine prior to that.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue
2012 Escape Limited w/park assist
2010 F150 Supercrew XTR 5.4 4x4
2008 Kawasaki Concours 14 (street)
2008 Kawasaki ZX10R (track only)
pozi240 is offline
Old 10-03-2012, 01:31 PM   #24
cobie56
Fan#: 84403
If it's not a simple button/switch on/off, no matter the make or model, it's a major flaw in engineering.... Why re-invent the wheel to make it 'square'?
cobie56 is offline
Old 10-03-2012, 01:56 PM   #25
ralck
Fan#: 96372
What I Drive: My sister's car while it is salty
FF Reputation: 1 ralck Good Standing Member
The ST2 I test drove had a button on the dash called "Sport mode." It turned ESC and TSC off (or at least made them much less aggressive).
ralck is offline
Old 10-03-2012, 02:01 PM   #26
Dysan911
Fan#: 95746
Originally Posted by PratoN View Post
Must be nice... but did you have transmission fluid leaking on the outside of your transmission? I fear that if I don't have that issue, no one will even look at clutch(es).
That's correct. I had the symptoms and it was only one day that I was tinkering under the hood with removal of the Snorkel (Intake mod) that I dropped a tool. I got under the car and removed that felt panel that covers the bottom of the engine compartment (not really removing it, just enough screws to reach in and retrieve the tool I dropped). Thats when I spotted the big ole bead of Oil/FLuid dripping.
2012 FF Ti HB Platinum White Tricoat, Built 12/11, 401A + Parking Technology Package and MFT w/NAV at 3.5.1
Dysan911 is offline
Old 10-03-2012, 02:03 PM   #27
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
Same here...it wasn't by choice. My car operated exactly as I liked it when I bought it, which is why I spent $30k on it. I wouldn't have purchased a car I wasn't satisfied. Then, a year later, Ford forces me to get an update that screws up the operation of the vehicle and makes it perform like a completely different car...in the worst way possible. They even threaten to cancel your warranty on powertrain issues if you don't get the update. That would be fine if the update were tested by more than 2 people that apparently don't understand cars and how they should operate.
Either way...the more people that can test this the more results we'll have to list for Ford. The fact that not a single engineer has found a correlation between the TCS update and the shudder would be mind-blowing if we hadn't already been struggling with the ineptitude of the MyFord Touch team. Now it just seems par for the course in the feigned "New" Ford Motor Company.
hotleadsingerguy is offline
Old 10-03-2012, 02:05 PM   #28
hotleadsingerguy
Fan#: 86687
See I've taken that shield off 4-5 times already (oil changes, usually) and never really looked. I've looked for oil leaks after changing it and gave a quick inspection, but haven't really seen any leaks. I've seen a bit of staining, but I naturally assumed it was just road dirt and road wash that had dripped down the housing. I'll have to check it out a bit more often. When you saw actual liquid down there was it shortly after a drive? Does it "leak" more often while driving it/after driving it?
Old 10-03-2012, 02:06 PM   #29
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 8,143, Level 60
Points: 8,143, Level: 60 Points: 8,143, Level: 60 Points: 8,143, Level: 60
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 8%
FF Reputation: 11 Joeywhat Great Standing Member
Only takes me a second to turn it off
Hatch Nation #29
Joeywhat is offline
Old 10-03-2012, 02:10 PM   #30
nseah
Fan#: 101824
What I Drive: 2012 Sterling Grey Ford Focus SEL
FF Reputation: 1 nseah Good Standing Member
Awesome! same problem I kind of ignore it now. So youre saying there's no way to keep the traction control off? It doesn't retain my settings?
-Nate
2012 Sterling Grey Ford Focus SEL Hatchback
nseah is offline
