Odd Oil issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2012, 11:54 AM   #1
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007 Focus
FF Reputation: 4 VEGAS Good Standing Member
Odd Oil issue
I take my car over (Insert Fast Speed Here) ((happy?)) mph often... I just installed a 2.3L motor about 3 months ago.. no issues till recently I am getting a engine oil lite flickering after I abuse the engine, but there is plenty of oil and oil pump seems to be working fine.. no shavings or anything.. Wondering it engine pressure has something to do with it, installed a Valve cover filter and killed the vent line to intake, since at these high speeds I was sucking oil out into the intake and killed a motor. Doing a BSD in the next few months to get more oil in motor. need to locate a oil baffle. So does anyone know the relationship of the oil pressure switch and the motor with this 2.3L?
Light flickers at idle, on braking, when under load, no issues, when not abused no issues.. I assume just get a Real Pressure gauge and find out the real deal, anyone install one yet?
VEGAS is offline
Old 10-02-2012, 01:08 PM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
A few questions:
1. Are you hitting those speeds on public roads?
2. What made you think you were sucking oil out of the engine?
3. Why did you disconnect the PCV system? (At high engine speeds, where is the increased volume of "oily byproducts", generated by the crank flying through the oil, going since there is no vacuum to open or close the PCV valve?)
I can see the advantage of disconnecting the PCV system but if you left the stock PCV valve in place then all that byproduct is trying to force its way up and out of the valve cover. If you don't want to get a PCV valve delete plate then you can gut the stock PCV valve (See sporadic's first turbo build thread).
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 10-02-2012, 02:47 PM   #3
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
Points 530, Level 10
Points: 530, Level: 10 Points: 530, Level: 10 Points: 530, Level: 10
Level Up 60% Completed
FF Reputation: 1 drewts86 Good Standing Member
My first thought might be oil temps; both because of the abuse as well as the desert temps out there in Nevada. If this turns out to be the case then something like the oil cooler kit from FSWerks.
drewts86 is offline
Old 10-02-2012, 08:43 PM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,750, Level 76
Points: 13,750, Level: 76 Points: 13,750, Level: 76 Points: 13,750, Level: 76
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Pull the balance shafts out & add a plug & stake it. Thats what I did. A baffle works for corners. I used a PT performance windage tray & their bsd plug. Look up the speed3 section.
felixthecat is offline
Old 10-02-2012, 09:16 PM   #5
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,226, Level 87
Points: 19,226, Level: 87 Points: 19,226, Level: 87 Points: 19,226, Level: 87
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 9%
FF Reputation: 7 badazz2010focus Good Standing Member
oil turns to almost the constiency of water when really really hot.
badazz2010focus is offline
Old 10-02-2012, 09:16 PM   #6
badazz2010focus
Fan#: 78166
Forum Activity 9%
oh and once the mods get ahold of this they are gonna shut you down and give you a warning.
Old 10-02-2012, 09:50 PM   #7
VEGAS
VEGAS's Avatar
Fan#: 75680
Closed track.. the RPMs at them speeds is the issue.. not the speed. Edited the speed in original post as to not offend cops..
so anyway, the oil issue seems to be fine when the engine is cool.. it is 100 degrees but I have had this car in hotter weather..
get on it again today and sure enough same issue, I will change out the oil and see what it does..
VEGAS is offline
Old 10-02-2012, 09:58 PM   #8
VEGAS
VEGAS's Avatar
Fan#: 75680
BTW its the not PVC that is disconnected, that is still there making Positive air flow, this is the vent at the rear of the valve cover, and why did I think it was sucking out the top, simple, No oil in blown engine, thick oil film in intake.. muffler and that was just in three weeks of the new engine that has been replaced, beside 3 techs that were from the company who sold me the engine came up with same idea. That is why you should never use synthetic when you break in motor, never seen smoke since it wont burn easy to show that problem, here I am with a Breather Filter at the rear of the engine and not using a hose to the intake and I still have oil... when you hit 7k RPM it is not the same as 4.5k RPM.. it turns the oil into a mist in the valve cover.. sucks it out. So either a Oil catch can is needed or a filter, since I am not using turbo yet I went with Filter..
like this one...
VEGAS is offline
Old 10-02-2012, 10:00 PM   #9
VEGAS
VEGAS's Avatar
Fan#: 75680
I still have the OEM oil in motor to break it in, maybe its time for the Synthetic and BSD, not even 2000 miles yet
VEGAS is offline
Old 10-03-2012, 07:42 AM   #10
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
I would agree with this.
From what I know about the PCV system, air enters the valve cover from intake system (after the MAF so its already metered), flows down through the engine collecting contaminants finally exiting through the PCV valve to go back into the intake manifold to be burned off by the engine. If you pulled the PCV hoses and left the stock PCV valve, the valve is closed and probably won't open letting the nasty stuff out.
I would suggest the balance shaft delete and get the crankcase venting system setup correctly. Maybe even look into a oil cooler. IIRC the Ford Escape has a oil cooler setup from the factory; the oil filter adapter bracket will bolt right onto our engines; just need to find a suitable place to tap into the coolant lines after the radiator.
1988 F150 Custom
D23 Crew: #07
