Turn Signal Lights Stay On - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2012, 11:28 AM   #1
joesperformance
joesperformance's Avatar
Fan#: 92411
What I Drive: 01 Focus SE Sedan, Zetec
FF Reputation: 3 joesperformance Good Standing Member
Exclamation Turn Signal Lights Stay On
I have an 01 Sedan Zetec MTX.... I changed my tail light and front light bulbs (between headlights), all the running lights, brake lights, and blinkers are working.... But when I noticed that the blinkers are blinking really fast, but front and rear are both working..... And when I turn on the parking lights or headlights, that the blinker lights on gauge cluster come on and stay on constent.....
Y are the blinkers blinking fast?
Y are the blinker lights on Gauge Cluster staying on constent?
I included a pic of the constent lights on, took it last night on my way home..... 1st pic is with flash on, 2nd pic is with flash off.... Took pic both ways, to make sure was able to see what I ment.... I was just cruising, no flashers, blinkers, foot not on brake, just headlights on and driving.....
http://www.firebirdnation.com/forums/uploads/1341751582/gallery_13330_2406_139330.png
Sedan Revolution #232
joesperformance is offline
Old 10-02-2012, 12:04 PM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,739, Level 58
Points: 7,739, Level: 58 Points: 7,739, Level: 58 Points: 7,739, Level: 58
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Fast blinking usually means one of the lights in the system is out. You will have three lights on each side to check; front, rear and side markers. I know you said the front and rear are working but what about the side markers, they should be blinking the same as the front/rear?
I'd check each light individually (just remove and reinstall) and then try the turn signal.
If its not a light that is out then its a short or bad ground in the system. Id guess its probably not a fuse but its something you can check as well.
rambleon84 is offline
Old 10-02-2012, 03:14 PM   #3
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,584, Level 53
Points: 6,584, Level: 53 Points: 6,584, Level: 53 Points: 6,584, Level: 53
Level Up 17% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Are you running LED's?
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 10-02-2012, 03:53 PM   #4
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
FF Reputation: 68 TerryB Excellent Standing Member
If so, you'll need resistors. Each bulb will need a resistor. The low wattage is signaling a bulb is out.
Here is one type.
TerryB is offline
Old 10-04-2012, 10:01 AM   #5
joesperformance
Fan#: 92411
Yes, I am....
Here is one type.
is this the right one? http://www.superbrightleds.com/morei...r-kit/190/831/
Old 10-04-2012, 03:19 PM   #6
TerryB
TerryB's Avatar
Fan#: 34559
Yes, RL-650 is the one. Get 4. Advance and autozone have the ceramic ones. I think they cost $11.00 for two. They stink though. The wiring is very brittle and break off easily.
TerryB is offline
Old 10-04-2012, 04:12 PM   #7
joesperformance
Fan#: 92411
I dont mind spending a few extra bucks on some that dont smell and wont burn out quickly, and has better wiring that wont melt or get brittle and break..... some things are worth the extra money....
Old 10-04-2012, 04:36 PM   #8
TerryB
TerryB's Avatar
Fan#: 34559
LOL, I meant they stink as in they are a piece of junk. Not that they smell.
TerryB is offline
Old 10-04-2012, 08:57 PM   #9
joesperformance
Fan#: 92411
oh ok, lol... i know how some things when they get hot, they have that burnt smell, so i thought thats what u were meanng.... lol
is that link i posted a good place to buy them from or is there a better place?? i want something that works and im not going to have problems out of.....
here's link again, so dont have to look for it....
Here's a couple other places i found, too...
http://www.lskoncepts.com/store/load...ngle-p-293.php
http://www.ledtronics.com/Products/P...s.aspx?WP=1170
http://www.etrailer.com/Accessories-.../P230004C.html
Old 10-05-2012, 03:34 AM   #10
TerryB
TerryB's Avatar
Fan#: 34559
Go with the superbrightleds. That's the least expensive. Just make sure they are 6 ohm 50 watt. The RL-650. The bottom link are the ones to stay away from. When the wire breaks, it breaks right at the creamic part. You'll have nothing left to use.
TerryB is offline
