Select Shift "Sport Start" - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-04-2012, 12:09 AM   #31
Hodge Podge
Hodge Podge's Avatar
Fan#: 96120
What I Drive: 2012 5-Dr Se Sport Pkg Ingot Silver
FF Reputation: 1 Hodge Podge Good Standing Member
Maybe it is a convenient side effect of the BOA function or some other feature, but it sure acts like a typical launch control system. If it really is the accidental side-effect of some other feature though, someone in Ford marketing is probably going "Damn, we could have advertised that!!"
On a more serious note, I was under the impression that it required "S" mode to be engaged and traction control to be disabled (selected "Off", not fuse pulled, etc..), but apparently that may be incorrect.
Anyone with a non "S" transmission tried to use this "nameless" feature?
And now the less serious side thoughts:
The car was designed to be able to handle stop & go rush-hour traffic...think about it...800~1000rpm, engage, disengage, repeat, repeat, repeat.
Really think one controlled 2500~3000rpm launch is going to hurt it? It's a 2.0...it's not at peak anything yet...
____________________
Hodge Podge
2012 Se Ingot Silver 5-Door w/ 201A & Se Sport Package
2001 Silverado 1500 RCLB 4x4 4.8L 5-Speed
Hodge Podge is offline
Old 10-04-2012, 12:15 AM   #32
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,060, Level 67
Points: 10,060, Level: 67 Points: 10,060, Level: 67 Points: 10,060, Level: 67
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Originally Posted by Kabigon View Post
Where is the BOA strategy for the Focus documented?
Well from the various articles I've read its supposed to shut the throttle entirely on all DBW Fords since 2010 and started in 2004/2005.
E.X. http://www.thecarconnection.com/news...e-new-standard
"Ford
Ford began migrating brake-throttle override, or Brake Over Accelerator (BOA), as the automaker calls it, in 2004 and the first product it appeared on was the 2005 Ford Escape Hybrid. By the end of calendar year 2010, it was implemented on nearly 100 percent of Ford and Lincoln light-duty models (excluding select low volume vehicles, such as certain trucks with a Cummins diesel engine). Owners of these trucks may not want BOA because they are backing up trailers or putting boats in the water, etc.
Brake Over Accelerator is a Ford-designed system. It is on manual and automatic transmission vehicles and operates the same. BOA is also on Ford hybrid and electric vehicles but operates a little bit differently than conventional powertrain vehicles. The system works the same way but the software calibration is a little different.
The BOA system monitors the accelerator pedal and the brake pedal position. If it senses brake pedal application and accelerator position not changing (for example, the accelerator is stuck or trapped), the electronic throttle is driven closed to idle position by the powertrain control module. As the throttle is driven closed, the brake force acts on the vehicle and it slows down—to a complete stop if the driver continues to apply the brakes.
Ford says that the system acts “very quickly.” When the brake is released, the system resumes normal operations, but the throttle is ramped back to the requested pedal position to allow a controllable acceleration. It also works in reverse."
suss6052 is online now
Old 10-04-2012, 12:35 AM   #33
Kabigon
Fan#: 88299
Points 4,414, Level 42
Points: 4,414, Level: 42 Points: 4,414, Level: 42 Points: 4,414, Level: 42
Level Up 32% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 11 Kabigon Great Standing Member
"Ford
The strategy used on various models may not be consistent for a number of reasons.
In any case, blasman confirmed the strategy used in the Focus with the DCT:
The clutches are disengaged and the throttle is limited to a "no load" condition.
Kabigon is online now
Old 10-04-2012, 12:50 AM   #34
Kabigon
Fan#: 88299
Forum Activity 15%
Actually, it is not launch control, BOA, or in fact any kind of unusual side effect.
As I tried (rather unsuccessfully) to point out in a previous post, the accel, clutches, and brakes are simply operating normally.
1) With your foot firmly on the brake pedal, the brakes are applied and the clutches are disengaged. (this is NORMAL operation)
2) When you release your foot from the brake pedal and *any* gear is selected, the car will start to move as one of the clutches engage. (this is NORMAL operation)
So far, we have established that the brakes and clutches are operating as they would in normal everyday driving.
...but what about the throttle?
3) When you press the accel pedal to the floor and no load is applied to the engine, the electronic throttle will limit the RPMs to ~3500 (I'm not certain if the RPM depends on engine type or PCM calibration). It *does not matter* if the transmission is in P, R, N, D, S, or L. (this is NORMAL operation)
Old 10-04-2012, 01:36 AM   #35
MyThIc3LiTe
MyThIc3LiTe's Avatar
Fan#: 95163
What I Drive: 2012 Focus Titanium Blue Candy
FF Reputation: 4 MyThIc3LiTe Good Standing Member
Except for the fact that when you put it into S, turn off TC, brake + throttle it holds at 2700rpm.
Your 3500rpm is just the natural rev limiter ALL cars have but when you do that same procedure on the Focus it holds at 2700rpm.
Aka launch sweet spot.
If it held at 3500 as simply a rev protector it would make for useless launches.
2012 Ford Focus Titanium Blue Candy Hatch 2009 Suzuki Swift+ - Traded in 2006 Lincoln Zephyr - Traded in
http://www.aniteshjaswalphotography.com
If you live in Edmonton, AB I would be more then happy to do a shoot with you!
MyThIc3LiTe is offline
Old 10-04-2012, 07:02 PM   #36
Kabigon
Fan#: 88299
Forum Activity 15%
With TC off, the throttle/RPM limit is the same for all gears (S, D, and R).
I doubt that there is launch control for reverse but everyone can draw their own conclusions.
Old 10-04-2012, 07:39 PM   #37
MyThIc3LiTe
Fan#: 95163
Well, we have a nice byproduct of 'BOA' cause it ends up giving better launches then just flooring the throttle at a stop.
Old 10-04-2012, 09:42 PM   #38
Hodge Podge
Fan#: 96120
Launch control for reverse. HA!!
It would be so bizarre if it worked that it would actually be cool!
Maybe in a slightly screwy redneck way, but still cool.
Joe Redneck - "Bet yer fancy I-tal-yun sports car can't do this!!"
And who knows, in 20 years, it could be useful...
"It's demolition derby night at the fairgrounds, and reverse is the gear of choice."
Hodge Podge
