Go Back   Focus Fanatics > Model Specific Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 10-01-2012, 07:34 PM   #1
mitchv
Fan#: 79720
What I Drive: 2003 blue zx3
FF Reputation: 4 mitchv Good Standing Member
Where is the best Grounding spot in hatches?
I drive a 2003 zx3 and was wondering where the best grounding spot is in our hatches. Has anyone actually used a DMM and tested it?
mitchv is offline
Old 10-01-2012, 10:37 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2002 ZX3
FF Reputation: 18 freemind Great Standing Member
Buy-Sell-Trade Rating: (16)
I drilled a hole on the spare tire bracket. But, then again, I am only running 700 watts in the current form. Many use the rear seat belt mount.
133whp-126ftlbsTQ Eclipse CD8443,JBL Px300.4, JBL GTO7001, PPI 356cs, JBL p1022 in .95 cubes, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 10-01-2012, 10:41 PM   #3
mitchv
Fan#: 79720
Hmm looks like ill have to stop being lazy and run a temporary wire, im grounded to where the stock sub bracket bolted into but im looking for something better. Pushing 1500 watts now
mitchv is offline
Old 10-01-2012, 11:05 PM   #4
freemind
freemind's Avatar
Fan#: 67513
Are you getting any dimming?
What is the meter reading?
Hatch Nation #140
freemind is offline
Old 10-02-2012, 12:49 PM   #5
mitchv
Fan#: 79720
Im getting tons of dimming I dont have a volt meter in the car and Im afraid to have it parked playing because I dont want to drop belowe 12volts and hurt my amps. But yes a ton of dimming is occuring, thinking I might upgrade big 3 to 4/0 OFC welding wire.
mitchv is offline
Old 10-02-2012, 02:09 PM   #6
freemind
freemind's Avatar
Fan#: 67513
Ygpm
Hatch Nation #140
freemind is offline
Old 10-07-2012, 09:12 AM   #7
Jeffrosilver07
Fan#: 104592
What I Drive: 2007 Silver Focus SE
FF Reputation: 2 Jeffrosilver07 Good Standing Member
I had an 02 SVT and now have a 07 SE, I used the same grounding bolt in both cars and had very good success with it. I used an impact gun to remove the back seat back bolts and then a dremel tool to get rid of the paint. Sandwiched the ground between the metal floor and the seat back and put the bolt back in. I have a 0 gauge ground so the ring terminal is pretty big and was able to fit around the bolt. Neither cars had/have any noise issues from placing the ground in that location. Hope this helps.
Jeffrosilver07 is offline
Old 10-07-2012, 09:20 AM   #8
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
rear seat bracket or shock bolt, I currently just rtun a negative to the front tho
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
Old 10-08-2012, 03:29 AM   #9
thingsidont
Fan#: 90749
What I Drive: 2001 sterling grey ZX3
FF Reputation: 1 thingsidont Good Standing Member
any luck on fixing your dimming cause im running about 1200w and ive done the big3 and i still got dimming
thingsidont is offline
Old 10-08-2012, 03:50 PM   #10
freemind
freemind's Avatar
Fan#: 67513
Class D or, A/B amps?
What is your voltage(with the car running and the system off)at the battery?
Now check it with the system on.
Post the variance.
Hatch Nation #140
freemind is offline
