Hid not working on-- - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-01-2012, 04:50 PM   #1
Flying56eagle
Flying56eagle's Avatar
Fan#: 69819
What I Drive: 2009 RED SANGRIA METALIC SES COUPE
FF Reputation: 11 Flying56eagle Great Standing Member
I have the Bi XENON For my 09, works great tell I try my brights, and blow a fuse every time, what do I need and please provide a link to were I can purchase the fix
Thanks
Stay Focused
Some say I give them hell, I just tell them the truth , They think it's hell
Flying56eagle is offline
Old 10-01-2012, 05:00 PM   #2
Baldurs390
Baldurs390's Avatar
Fan#: 86071
What I Drive: 2009 black ses
Points 3,635, Level 37
Points: 3,635, Level: 37 Points: 3,635, Level: 37 Points: 3,635, Level: 37
Level Up 90% Completed
FF Reputation: 4 Baldurs390 Good Standing Member
check and see if you have water in any of the connection on the lights and ballast
FRPPFSWERKSDDMMassiveTruBenz
Baldurs390 is offline
Old 10-01-2012, 08:31 PM   #3
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,973, Level 87
Points: 18,973, Level: 87 Points: 18,973, Level: 87 Points: 18,973, Level: 87
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 9%
FF Reputation: 7 badazz2010focus Good Standing Member
they a high low kit?
badazz2010focus is online now
Old 10-02-2012, 05:07 PM   #4
JDBug182
JDBug182's Avatar
Fan#: 83895
What I Drive: 2009 Blue SES Coupe
FF Reputation: 3 JDBug182 Good Standing Member
Not familiar with the bi setup..... But are you running a fused relay from the battery?
mmmmmm...... fo-FoMoCo-coa??
JDBug182 is offline
Old 10-02-2012, 05:27 PM   #5
bmiglio72
bmiglio72's Avatar
Fan#: 79540
What I Drive: 2008 Vista Blue Ford Focus SE
FF Reputation: 2 bmiglio72 Good Standing Member
I used to have a bi xenon set....have the brights ever worked because if not its most likely the hi lo control box is defective so just send it back
bmiglio72 is offline
Old 10-02-2012, 06:54 PM   #6
badazz2010focus
Fan#: 78166
Forum Activity 9%
most people dont run hi/lows because they lows are plenty unless you live out in the middle of cow country LOL!
Old 10-04-2012, 01:08 AM   #7
klrfoucs
klrfoucs's Avatar
Fan#: 89955
What I Drive: 08 Black SES Coupe Mtx
FF Reputation: 1 klrfoucs Good Standing Member
i have a set of hid's that i havent really seen elsewhere, from what i understand bi xenon have 2 filaments, mine only have a single that is about an 1in and a half long maybe a tad more but they magnetically pull back in the h13 socket so it gets higher and wider, terrible lighting on my high beams thought, recently my passenger side light has been turning yellow so i think my ballast is about to go and on occasion one or the other doesnt turn on but turn off and on again and they both work?
2dr Mtx SES#037
klrfoucs is offline
Old 10-04-2012, 05:17 AM   #8
bmiglio72
bmiglio72's Avatar
Fan#: 79540
I used to have the same thing. I'm sorry to say I really doubt that is a fixable problem. I think it may be the ballast taking a dump. I also have the thought it might be the high low control box in the wiring because both of your lights are acting up.
Old 10-04-2012, 11:41 AM   #9
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Sounds like there is a short somewhere in your Hid system. Hard to say where exactly. maybe in the ballast maybe just in a wire.
Galatians 6:14
crice8 is offline
Old 10-08-2012, 02:13 AM   #10
Flying56eagle
Fan#: 69819
no water
yes that is why the are called BI exon
No I'm not, that is what I was woundering, because I blow the fuse every time, if I install the facktory set back everything works fine, when I install the hid. everything works also ecept the brights
this is my second set..
in pa for the inspection you have to have high and low beam switch working.
glad you found your problem..
it never worked for the start. second set
again second set.. So no has a fuse system I gather from the responses, and everyone seams to just buy the single cheaper one filament hids, and never use there brights anymore? am I missing something here. Maybe I will just put my factory system back in.
Stay Focused
