2012 Focus Door molex connector for speaker wire - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-30-2012, 08:16 PM   #1
majorChibi
Fan#: 103279
What I Drive: 2012 Oxford White SE
Points 173, Level 3
Points: 173, Level: 3 Points: 173, Level: 3 Points: 173, Level: 3
Level Up 46% Completed
FF Reputation: 1 majorChibi Good Standing Member
How do I disconnect this?
Do I need to remove the white part first?
I'm trying to see if there's any room to route a thicker gauge speaker wire by drilling out unused pins and routing through the connector.
What gauge is running out to the doors? and will it handle 100WRMS per speaker.
I've tapped my LC2i at the harness and the wire size appears to be an 18 or 22, but there are some decently thick wires going to the door. I couldn't find the White and White/brown wire in the front left door.
majorChibi is offline
Old 10-01-2012, 09:11 PM   #2
majorChibi
Fan#: 103279
Points 173, Level 3
Figured it out.
To get the molex connector out of the hole:
Hit the clips on both the top and bottom and the entire molex assembly will slide out.
there are another set of clips on the top and bottom of the assembly to disconnect.
There are two separate connectors.
There is very little to no room to get a decent sized speaker wire through.
I did find that the the hole below the molex connector can be used to wire the speaker wire through. I will be using that and running it through the rubber snake into the door.
I'll post pics if anyone wants them
Old 11-26-2012, 07:43 PM   #3
Besbro
Besbro's Avatar
Fan#: 102785
What I Drive: 2012, black SE Sport
FF Reputation: 1 Besbro Good Standing Member
Hello, I would sure appreciate pics of this.
Thanks!
Besbro is offline
