Improving 2008 Focus Sedan Aerodynamics - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-10-2012, 03:21 PM   #21
StockTalon
Guest
Fan#: 94771
What I Drive: 2012 Focus Titanium
FF Reputation: 1 StockTalon Good Standing Member
Originally Posted by emsvitil View Post
Ok...
420 miles / 75 mph = 5.6 hours
420 miles / 55 mph = 7.64 hours
420 miles / 37 mpg = 11.35 gallons
420 miles / 45 mpg = 9.33 gallons
So can either save 2 hours of travel time or 2 gallons of gas.
At $4 per gallon, the 2 hours costs you $8........
How much is 2 hours of your time worth?
A lot more than $8.
StockTalon is offline
Old 10-10-2012, 03:29 PM   #22
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
Ok...
Well at any rate the company paid for my fuel. This is only an example. You drive a lot of miles, so take my example and multiply it by 52 weeks. Now multiply it by the expected life of your vehicle. At 52 weeks you're looking at either saving $416 in fuel or 104 hours over a year. Now add in the increased wear at operating a vehicle at higher speeds. Its all perspective and what you want. If you want fuel savings lower speed will grant you that, case and point
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
Old 10-10-2012, 03:35 PM   #23
Gettysburg150
Fan#: 97408
Also on a side note, I have a set of Saab turbo wheels that are supposed to be designed for better brake cooling/venting. My snow wheels are currently on these and I gained back one mpg from the loss of having snow tires, if that makes any sense lol. I swear they decreased drag since the weight is about the same but I can't really confirm this without a wind tunnel
Old 10-10-2012, 05:35 PM   #24
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
Leave early and slow down!
You should know your mileage eventually starts to drop anywhere above 55-65mph.
Though honestly I believe that is a myth.
My old car was a 4 speed auto, it shifted at like 70mph into 4th gear.
So me going 5-6 over the 65mph speed limit caused it to shift up and drop in RPMs.
I guess really,it just depends on the car and when it shifts
A7xschecter6661 is offline
Old 10-11-2012, 10:10 AM   #25
Gettysburg150
Fan#: 97408
Gearing and rpm are what play into this. My magic number is about 2k in my car
Old 10-11-2012, 03:47 PM   #26
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,761, Level 24
Points: 1,761, Level: 24 Points: 1,761, Level: 24 Points: 1,761, Level: 24
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
Forum Activity 3%
FF Reputation: 5 Miller88 Good Standing Member
If I take it easy, I can get my Focus up to 45MPG. I REALLY drove it easy, did the coasting thing and never went above 50mph ... and actually hit 50MPG (50.3).
Gotta drive it very lightly.
A belly pan would have to be secured and kept away from the cat and exhaust, but it has potential. I've been considering getting some old signs and making a belly pan for it. I think it's doable.
The other thing is, blocking off of the upper grille. A lot of peopple have had favorable results by blocking off the "upper" grille on the two grille bottom breathing cars.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 10-12-2012, 08:16 AM   #27
Gettysburg150
Fan#: 97408
Also you want to keep it as light as possible, since adding extra weight is not going to do you any favors.
Look in your trunk and see if there is any unnecessary items that you are carrying daily and remove these.
The bottom of the focus isn't the smoothest in the world but I would compare it to a German sedan. Major difference is we dont have a splash pan directly under the engine. Really they are quite similar minus the fwd/rwd. How much benefit that would bring? I dont know. I do know there's not a BMW on our lot that can touch my fuel mileage fwiw
