Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 09-29-2012, 10:29 PM   #1
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
FF Reputation: 10 GreySkorpion Great Standing Member
Buy-Sell-Trade Rating: (4)
step by step rear camber bolt with pictures needed
I have searched high and low, here and on Google and still can't find a perfect step by step including pictures and explanation of which way the washers and lobe should face when installing rear camber bolts. Please provide a link or very detailed explanation. I hope I just missed it out there but I have seen reviews only partially cover the install. Of course, I am trying to correct negative camber. Thanks!
GreySkorpion is offline
Fan#: 1
Old 09-29-2012, 11:29 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
This was in the FF "how to's": http://web.archive.org/web/200708140...ltsinstall.htm
Couple words of advise, a sharp chisel can usually be used to break the welds. The bolt heads have an arrow on them. For an initial setting, point both arrows toward the center of the car (inward) at about the one o'clock position. You'll need to get an alignment for a more precise setting.
Geezer is offline
Old 09-29-2012, 11:54 PM   #3
MattDzx3
MattDzx3's Avatar
Fan#: 99676
What I Drive: 2002 Red ZX3
FF Reputation: 2 MattDzx3 Good Standing Member
This has camber arms and bolts: http://www.focusfanatics.com/forum/showthread.php?t=199050
MattDzx3 is offline
Old 09-30-2012, 09:28 PM   #4
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
FF Reputation: 7 Blue5ive Good Standing Member
Buy-Sell-Trade Rating: (8)
Ask and yee shall receive.
Team Focalize
Hatch Nation #9
"Some people feel the rain, others just get wet"
Blue5ive is offline
Old 09-30-2012, 09:45 PM   #5
GreySkorpion
Fan#: 94674
Do you mean the driver side arrow at 1 o'clock and the passenger side arrow at 11 o'clock? Just want to get the lobe facing the same way on both sides until I get an alignment. Thanks
Old 09-30-2012, 11:41 PM   #6
Geezer
Fan#: 1427
Yes that's generally correct but then again it can depend which side you initially inset the bolt on (toward the front or back of the car).
Geezer is offline
Old 10-01-2012, 02:05 AM   #7
GreySkorpion
Fan#: 94674
Okay I haven't pulled it apart yet to see if the bolts are in the same way on each side, from my reading to initially take away negative camber face the lobe pointed straight in so that sounds like the 1 and 11 position you are referring to Geezer.
Old 10-01-2012, 09:12 AM   #8
Geezer
Fan#: 1427
The idea is to maintain some camber (-1.5 degress or so and reducing it if you exceed that much). I found that a good "starting position" is about the equivalent of "one hour" from vertical and toward the center of the car. Naturally every car will respond a little differently and that's were an alignment becomes critical after installing the bolts. Remember to tell the alignment tech that you have camber bolts and the amount of camber that you want or you just wasted your time installing them. I painted my bolts heads yellow so the tech could easily find them.
Geezer is offline
Old 10-01-2012, 05:30 PM   #9
GreySkorpion
Fan#: 94674
Oh I will tell them about the bolts, one of my friends is a service manager at a Quality Care center I use. Thanks for all your help Geezer. I am asking for -1 degree camber and .02 inches toe in on each side, or if they figure each side in together for toe, .04 inches.
