Sunroof Won't Respond! Need Immediate Help - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 09-29-2012, 08:06 PM   #1
kb911
kb911's Avatar
Fan#: 91864
What I Drive: 2012 Ingot Silver SE Hatch 5spd
FF Reputation: 1 kb911 Good Standing Member
I am currently 1,600 miles away from home and storm clouds are approaching. I went to close my sunroof which worked perfectly about two hours ago and suddenly....nothing no hint of a block the sunroof won't respond to input from the switch. is there anyway to manually close it or has anyone encountered a similar problem there is a huge storm on the way and I have to drive back home tomorrow
kb911 is offline
Old 09-29-2012, 08:17 PM   #2
funktional
Fan#: 100157
What I Drive: 2006 Silver ZX3 S (totaled)
FF Reputation: 1 funktional Good Standing Member
Not sure if it's the same but another car I had with a power sunroof had a little plastic cap that you could remove and there was a tool in the spare tire jack that you could use to manually close it.
Sorry, my focus didn't have a sunroof.........good luck
funktional is offline
Old 09-29-2012, 08:20 PM   #3
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 GTI
FF Reputation: 27 Zillon Great Standing Member
Try disconnecting the negative terminal from the battery for a minute to force a reset of the electronics in the car, and try again.
Just be careful you don't give yourself a jolt.
Joined the dark side.
Zillon is offline
Old 09-29-2012, 08:48 PM   #4
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
FF Reputation: 5 dbenney Good Standing Member
also did you do the obvious and check to see if the fuse has poped?
dbenney is online now
Old 09-29-2012, 08:58 PM   #5
kb911
kb911's Avatar
Fan#: 91864
already checked fuses even ones similar in usage just in case its a this is not working but over here is the real problem...just disconnected the battery. took out the sunroof switch checked for short...nada this is getting aggravating i have to drive from florida to ri tomorrow. this is the second bad luck ive had the first being on the way down when my partner was driving and he hit a truck tire on the highway causing some minor damage to the under side body panels and a bracket to the back bumper
kb911 is offline
Old 09-29-2012, 08:59 PM   #6
forceflow2
Fan#: 89089
What I Drive: 2013 Mustang GHIG V6 Premium
FF Reputation: 1 forceflow2 Good Standing Member
Be careful with poped fuses. They're very protective of their fancy hats.
2012 Ford Focus Sterling Grey Metallic SEL Sedan
Ordered: 8/6/11 VIN: 9/6/11 Build Date: 8/30/11
Delivery: Originally estimated 9/19/11. Delivered 9/22/11. picked up 9/24/11.
Reacquired by Ford under Lemon Law 01/16/13.
forceflow2 is offline
Old 09-29-2012, 09:32 PM   #7
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
FF Reputation: 1 jdetzel Good Standing Member
You did not say if you are getting power to the switch. Also, you looked at the owners manual for the procedure to reset the switch right?
jdetzel is offline
Old 09-29-2012, 09:57 PM   #8
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
What I Drive: DC
FF Reputation: 7 Chaos09 Good Standing Member
Stop at Walmart and get a tarp and a roll of duct tape. That will save you just in case. Then try to fix it properly. If it rains then use the tarp idea.
Sonic's MK3 Crew #9 Chaos!
www.DCSAutoworks.com
Chaos09 is offline
Old 09-29-2012, 10:10 PM   #9
Superd
Superd's Avatar
Fan#: 87917
What I Drive: '12 candy red titanium hatch
FF Reputation: 1 Superd Good Standing Member
If you have a chance drop by a ford dealer in the morning.
Superd is offline
Old 09-29-2012, 10:15 PM   #10
suss6052
suss6052's Avatar
Fan#: 95752
FF Reputation: 23 suss6052 Great Standing Member
What Ford dealer is open on a Sunday? None around here as far as I know, and I'm within driving distance of Dearborn.
suss6052 is online now
