Bonnet chip repairs. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Auto Washing, Detailing & Paint Protection
Auto Washing, Detailing & Paint Protection Discuss wax, polish, chamois, microfiber towels, simple cloth towel, scratch repair and paint protection. Use this Forum to discuss your cleaning tricks and techniques.
Old 09-29-2012, 07:43 PM   #1
sicskate
Fan#: 102301
What I Drive: Peugeot
Points 145, Level 2
Points: 145, Level: 2 Points: 145, Level: 2 Points: 145, Level: 2
Level Up 90% Completed
FF Reputation: 1 sicskate Good Standing Member
Work was a tad slow last week, so i thought i'd take advantage and make this quide.
the bonnet in question,
2012 Ford S-MAX
Panther black.
the chips were 3-4mm in diameter each.
Start by scotching the chips, making sure the centre of the chips are etched.
This is to help the new paint hold.
next its time for paint 1:1:1 base/lacquer/hardner
mix paint well.
Clean the area with silicon inferno (no pics).
this is to remove dust from the scotching from the chip.
Add the paint with a thin brush, i used a 1mm fine tipped brush.
When adding the paint, you don't want to put a massive blob in, but you ideally need the new paint to overlap the outside of the chip by 0.5mm.
Time to get some heat on it. 15mins at160 degrees C should do, but a few hours in the sun will do the job.
After a bake,
Due to the size of these chips, i decided to let this area cool and re-bake them again for good luck.
Once cooled, I'm using a paint shaving block to trim the new paint down to a closer to level point.
The dark shiny bits are the LOW parts.
So its time to scotch it up and put some fresh paint back in.
So after a re-bake and cool down, i've shaved it down again abd all was good.
A quick flat with some wet'n'dry 2000 paper and a rubber block to keep it flat.
Other chipped areas i was working on.
Time for some polish (med cutting compound)
with a lambs wool head.
Area polished.
Time for a very soft swirl / hologram remover with a very soft foam head on a slow steady speed.
Wiped down with a microfibre cloth
Now time for some wax. apparently up & down reduces shadows.
Left to cure for 5 mins and wiped off.
Finished article :dance:
And off it goes along the production line.
I'd like to add, that the bonnet was not detailed in anyway at this point.
sicskate is offline
Old 09-29-2012, 08:29 PM   #2
lyonsroar
Guest
Fan#: 63166
What I Drive: 2009 Volkswagen GTI
FF Reputation: 31 lyonsroar Great Standing Member
This is not really something a DIY'r would feel comfortable handling I would think.
GREAT results though.
The home repairer might be more comfortable with this:
http://www.drcolorchip.com/
lyonsroar is offline
Old 09-29-2012, 10:04 PM   #3
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 953, Level 16
Points: 953, Level: 16 Points: 953, Level: 16 Points: 953, Level: 16
Level Up 53% Completed
FF Reputation: 5 dbenney Good Standing Member
I guess it all depends on what you are comfortable with. I have done some painting and I would feel comfortable with doing that. Its basic touch up.
to the OP... great write up!
dbenney is offline
Old 10-02-2012, 12:41 PM   #4
Burns098356GX
Burns098356GX's Avatar
Fan#: 94777
What I Drive: 2013 Focus ST
Points 1,136, Level 18
Points: 1,136, Level: 18 Points: 1,136, Level: 18 Points: 1,136, Level: 18
Level Up 36% Completed
FF Reputation: 1 Burns098356GX Good Standing Member
Petty impressive, not something I've got the talent for though. I've got some doctorcolourchip coming this week, hope it works. My focus is tuxedo black which appears to be very similar to the European panther black.
Sent from my Nexus 7 using FF Mobile
Burns098356GX is offline
Old 10-02-2012, 02:38 PM   #5
gsxrboy
Fan#: 103574
What I Drive: 2012 Black Focus Titanium
FF Reputation: 3 gsxrboy Good Standing Member
Awesome article, thank you for writing this up. I am definitely not doing this myself, but at least I know what it takes to complete and I can hunt around for prices in my neighborhood.
2012 Focus Titanium Black Manual
http://www.fuelly.com/driver/gsxrboy/focus
gsxrboy is offline
Old 10-03-2012, 10:17 PM   #6
Burns098356GX
Fan#: 94777
Is this the type of work a body shop will do? I filled my own chips on my last car, which was mostly junk. I'd like to get a couple chips on the hood of my new focus taken care of. I always thought the only way to really fix that type of damage was to completely repaint it.
