Zetec Rough Idle Mystery Solved - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-29-2012, 06:31 PM   #1
drlenger
drlenger's Avatar
Fan#: 99839
What I Drive: 2003, Focus, SE
Points 527, Level 10
Points: 527, Level: 10 Points: 527, Level: 10 Points: 527, Level: 10
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 2 drlenger Good Standing Member
This is my 2000 SE Zetec, I also have a 2003 SE Split Port, you can see my other posts about the Famous Intake Valve Seat Drop on that one....these are cars for my kids, 17 year old daughter and 16 year old son.
But this post is about that mysterious rough idle issue with the Zetec. I have read a ton of blogs and posts about this issue. I spent that last 5 months trying to fix this problem and spent way too much $$. I started by changing the fuel filter, and snapped off the plastic elbow on the fuel pump so I had to change that too.....it was better but not fixed. I then started looking for vacuum leaks, and found that the two lines going from the DFPE sensor were cracked and weather worn, better but not fixed. I then changed the PCV line which was worn and was collapsing (very common).....better but not fixed. I then changed the motor and transmission mounts....better but not fixed. So then I changed the EGR valve and the Mass Air Flow sensor....you guessed it....better but not fixed. So I pulled the throttle body off and cleaned it completely. No change...... So I pulled the EGR Solenoid and cleaned the foam filter inside.....better but not fixed. Changed the DFPE sensor, no change.
Now understand this car was running great on the throttle, but would idle so rough it was shaking the entire dash board. It was much worse in reverse, and completely undriveable with the AC turned on. So I finally gave up, I took it took a local mechanic friend and said HELP ......
They ran some tests, reset the computer, reset the idle speed and also determined that the EGR valve that I had put on was not working correctly. Still rough.....so he says....where the !#$@#$$ did you get those motor mounts. I said from Orielly's. He said.....we only use Ford Factory motor mounts on these cars....they are finicky about that for some reason......
So I pulled all the mounts and returned them to Oriellys, no questions asked, they were great about it, and got my money back.....ordered the motor mount, trans mount, and anti roll mount from Ford. Replaced all three......and guess what....it is like a new car. You actually can't tell it is running at idle....in gear....with the AC on. Believe or not, I have this same Orielly's motor mount on the other Focus with the Split port and it works just fine.....
Absolutely unbelieveable.....all because of some cheap Chinese parts I spent hundreds of dollars and countless hours
Hope this helps others to save money and time! A wise man once told me.... Education costs....just don't take the class twice!
Frustrated Shade Tree Mechanic
drlenger is offline
Old 09-29-2012, 06:48 PM   #2
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
Points 1,505, Level 22
Points: 1,505, Level: 22 Points: 1,505, Level: 22 Points: 1,505, Level: 22
Level Up 5% Completed
FF Reputation: 5 scott7278 Good Standing Member
Sweet ride! Thanks for the write-up; it's amazing how something that doesn't cost all that much can cause such trouble!
scott7278 is online now
Old 09-30-2012, 12:37 PM   #3
DueceCoupe
DueceCoupe's Avatar
Fan#: 32955
What I Drive: 07 Infra Red ST,2002 ZX3.
Points 7,298, Level 56
Points: 7,298, Level: 56 Points: 7,298, Level: 56 Points: 7,298, Level: 56
Level Up 74% Completed
Forum Activity 2%
FF Reputation: 5 DueceCoupe Good Standing Member
Buy-Sell-Trade Rating: (29)
I have changed all the same parts You have and still am experiencing rough idle.
My idle is rough to the point it dips and almost stalls,cannot see how this could be motor mount related.
Did Yours also bog off the line if You went wot from a dead stop?
I used to be DueceCoupe,but now I gots a 4 door!
ST Crew Member # 666
DueceCoupe is offline
Old 09-30-2012, 01:55 PM   #4
drlenger
drlenger's Avatar
Fan#: 99839
no mine ran great once you gave it some throttle, just bad idle, you might get someone with good analyzer equipment to look at it. My EGR valve was replaced but was opening normally to 30% then slamming open the rest of the way and sticking open, made it pulse and bog down.....worth checking into. Have you checked into changing the throttle position sensor, you would have to change the entire throttle body because Ford changed it.
drlenger is offline
Old 09-30-2012, 02:13 PM   #5
DueceCoupe
DueceCoupe's Avatar
Fan#: 32955
Forum Activity 2%
I will try to get video of what mines doing and post it here.....
Was the pulse from the EGR happening around 2-2300 rpms?
Mine runs great,once its rolling,but if I hammer the gas....bog than takes off.
