02 SVT Focus doesn't start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-29-2012, 01:42 PM   #1
trekster
Fan#: 84883
What I Drive: 2002 Black SVT
FF Reputation: 1 trekster Good Standing Member
Hi,
I've been having issues with my car starting up. At first, If I pressed on the gas pedal while the car trys to start up, the car would start. The car would start up normally for a few days before I start having issues with turning on the car again. Recently, I had to jump start the car because doing my other method would no longer work. I took the car to autozone to see if it's either a bad battery or alternator. The battery passed, but the alternator was running at 13 volts. Fast forward to this week, the car doesn't turn on at all. I tried jump starting it and no cigar. The car keeps cranking, but it doesn't start.
I'm thinking it's the alternator, but I keep hearing on how it's a pain in the ass to get it out.
Are their any other things that I should checkout first before assuming it's the alternator?
Thanks,
Gil
trekster is offline
Old 09-29-2012, 05:01 PM   #2
trekster
Fan#: 84883
I'm going to check out the fuel filter and the fuel pump tomorrow. I'll keep you guys updated.
trekster is offline
Old 09-29-2012, 08:45 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,311, Level 100
Points: 51,311, Level: 100 Points: 51,311, Level: 100 Points: 51,311, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
If the car spins over then the Alt has nothing to do with it starting
Fuel psi
crank sensor
plug in on the coil pack is the 3 things that cause this the most on the Focus
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 09-29-2012, 08:59 PM   #4
trekster
Fan#: 84883
Fuel psi
crank sensor
Thanks for you help tom. I'll check those out.
trekster is offline
Old 05-30-2013, 10:10 PM   #5
boardliquid01
boardliquid01's Avatar
Fan#: 114884
What I Drive: 2003 Silver Ford Focus SVT EAP
Points 446, Level 8
Points: 446, Level: 8 Points: 446, Level: 8 Points: 446, Level: 8
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 6%
FF Reputation: 2 boardliquid01 Good Standing Member
There is a fuel shut off inertia switch on the passenger side kick panel. If someone kicks this it shuts the fuel pump off. It has a reset button on the top of it.
If there was no crank sensor input then there would be a CEL light on for random misfire on startup. Have you checked DTCs?
Coil pack is not connected or damaged. You can test for spark using a grounded spark plug tester.
Other than those basics you'll need to start checking engine DTCs for some clues to what is going on. My next guess would be something is wrong with the throttle position sensor or wiring.
boardliquid01 is offline
Old 05-31-2013, 09:22 AM   #6
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
The Focus is known to ware off the back side of the crank sensor , if it does this you get no fire and car wont start , most guys turn the car off , go in , come back out and car wont start because of the fly why rubbing on the back of the crank sensor
This is why I listed the crank sensor
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-31-2013, 02:14 PM   #7
Mystic544
Mystic544's Avatar
Fan#: 17917
What I Drive: 2003 Pitch Black SVT
FF Reputation: 1 Mystic544 Good Standing Member
Question
Tom...
"car wont start because of the fly why rubbing on the back of the crank sensor"
Is there a way to check for this?
Where is this sensor?
Thanks for your reply (even though my post is now gone?)!
? DTCs ???
TimmaY
2003 Pitch Black SVT Focus
1996 Mystic Cobra #544
VP www.midwestfords.org
Mystic544 is offline
Old 05-31-2013, 02:55 PM   #8
boardliquid01
Fan#: 114884
Points 446, Level 8
Forum Activity 6%
The crank sensor is on the transmission housing under the intake snorkel tube. You can pull the sensor out and check for impact marks.
DTCs stands for Diagnostic Trouble Codes. You can get a simple code reader and check Key on Engine Off DTCs.
Old 05-31-2013, 03:32 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
The crank sensor is on the block just above the oil pan below Cyl 4 , its the only think on the block in that area with wiring going to it
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-31-2013, 06:30 PM   #10
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,366, Level 42
Points: 4,366, Level: 42 Points: 4,366, Level: 42 Points: 4,366, Level: 42
Level Up 8% Completed
Forum Activity 2%
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
http://www.youtube.com/watch?v=3LcXP3kQsGw
NJSVTGUY is offline
