Oil change - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-29-2012, 05:48 AM   #1
fuhrer
fuhrer's Avatar
Fan#: 97830
What I Drive: 2001 silver ZX5
FF Reputation: 1 fuhrer Good Standing Member
Oil change
Hello guys,
I want to change oil and i would like any suggestions from you.
I have diesel Focus, 2001, 120 000 km (Albania)
Last time i use Castrol.
Please can you suggest me any brand and viscosity for my car?
Kind regards,
N'
fuhrer is offline
Old 09-29-2012, 07:38 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,705, Level 62
Points: 8,705, Level: 62 Points: 8,705, Level: 62 Points: 8,705, Level: 62
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
I don't have a diesel focus but I have another vehicle that has flat tappet cams so a high zinc content is advised. I use the Full synthetic Shell Rotella-T.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 10-01-2012, 07:48 AM   #3
fuhrer
fuhrer's Avatar
Fan#: 97830
Thank you Magus2727!!!
How about the viscosity?
fuhrer is offline
Old 10-01-2012, 11:18 PM   #4
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 58%
what does the user manual say? I am guessing its should be close to the same 5W20 or 5W30 that the normal Zetec or even Duratec have.
Hatch Nation #42
Old 10-15-2012, 03:30 AM   #5
fuhrer
fuhrer's Avatar
Fan#: 97830
The manual require 5W30, but does this change as the car get older?
fuhrer is offline
Old 10-15-2012, 04:02 AM   #6
FocusGhia
Fan#: 94579
What I Drive: 2001 Ghia 1.6
Points 543, Level 10
Points: 543, Level: 10 Points: 543, Level: 10 Points: 543, Level: 10
Level Up 86% Completed
FF Reputation: 3 FocusGhia Good Standing Member
Engine oil viscosity should never change due to an engines age, however, saying that you may find some old school mechanics recommend a thicker oil just before sale to quieten noisier engines temporarily:)
FocusGhia is offline
Old 10-15-2012, 04:08 AM   #7
fuhrer
fuhrer's Avatar
Fan#: 97830
Thank you Ghia!! :-)
fuhrer is offline
Old 10-15-2012, 07:51 AM   #8
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 58%
Thicker oil usually is a way to only cover up problems, such as valve train noise or oil leaks. The manual should have a variation saying g if you live in hot areas you can run a heaver weight oil if the temp is above xx deg F. Heaver weight oils take longer for proper flow through the whole motor, so on your cold starts more ware from oil starvation will occur with a heavy weight oil vs the lighter weight.
I think some have said that if its a full synthetic then due to its better "properties" you can run a lighter weight oil. I don't know how much stock I put into that.
I would run with the 5W30 unless you qualify for an exception as called out in the manual. Almost every 4-cyl motor I have seen or worked on has 5w30 as the factory recommended oil weight.
Hatch Nation #42
Old 10-16-2012, 02:23 AM   #9
amc49
Fan#: 96610
Points 3,390, Level 36
Points: 3,390, Level: 36 Points: 3,390, Level: 36 Points: 3,390, Level: 36
Level Up 27% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
'I think some have said that if its a full synthetic then due to its better "properties" you can run a lighter weight oil. I don't know how much stock I put into that.'
You're putting more in than you think, you're already doing it. 5W-30 now replaces the old standard which was 10W-40 on virtually all cars. Now we are dropping to 5W-20........
More bunk, I'll get flak for this but prove it wrong you cannot.
'Heaver weight oils take longer for proper flow through the whole motor, so on your cold starts more ware from oil starvation will occur with a heavy weight oil vs the lighter weight.'
If a heavier weight oil takes longer to flow into the motor, it will take longer to flow OUT of the motor. Any questions? Or does anyone think the oil is smart enough to know which way it is going?
The heavier oil will stay in place in bearings better because it's thicker, capillary action that retains oil in cracks works better on thicker fluids. The thinner oil that pumps in easier also runs out faster to give so-called dry starts, which I don't really believe in anyway. If there were any true dry starting the motors wouldn't last a month. I've pulled apart engines that sat for YEARS and they still had plenty of startup oil around the bearings, the idea just ain't so. But the oil marketing guys love you for thinking it!!
I use either straight 30 or 10W-40.............here in Texas oil thinning from heat problems hold sway over cold flow. I also use the big FL1 filter and change conventional non synthetic oil at 7500 miles.
amc49 is offline
Old 10-16-2012, 03:06 AM   #10
bumble21
Fan#: 95826
What I Drive: 2001, Black&Yellow, ZX3
FF Reputation: 1 bumble21 Good Standing Member
Oil heats up with the friction from the moving parts in an engine. Having it stay in longer isn't helping it at all. Use the oil the manufacturer recommends and you'll never go wrong. Thicker oil can help if the oil clearances have become larger from wear but it's just putting a bandaid on it. If you need to move to a thicker weight oil just do yourself a favor and replace the bearings and keep using the factory recommended oil.
bumble21 is offline
