05' 2.3 ST with a few problems. Need guidance on where to begin... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-28-2012, 08:54 PM   #1
bloostd
Fan#: 59310
What I Drive: 2005 Ford Focus ST Black
FF Reputation: 1 bloostd Good Standing Member
Arrow 05' 2.3 ST with a few problems. Need guidance on where to begin...
Hey Fellow Fanatics,
I've got some issues with my 05 ST I purchased almost a year ago... The same issues since I bought it with. Hell 60k miles, ST with heated seats, for 4500- salvaged title. Car looks completely fine and was fixed inappropriately. Great DD.
Anyways, When I turn on my headlights with out without fog/ parking lights, all my cluster instrument lights go out. If I play with it, putting pressure on it, and turning it, I can get the lights to stay on while in parking light mode- but when you turn fully to headlights- boom, the lights on the cluster gauge/ hvac all go dead.
Whats the deal? What do I need to do or buy?
Next thing,
The E-Brake handle spring-push-button broke. It won't say locked. What part do I actually need? Can i just replaced the spring or do I need the whole part? Which part would that be?
3rd issue, HVAC controls. The blower only works in the 3 position. The rest of them do not. I'm guessing its the control switch?
4thly, What kind of maintenance should I do at 75k mile interval? I've replaced the brakes, and changed the oil- thats about it.
Anything I need to worry about?
Thanks guys!
Have a great weekend.
Bret
2005 Focus ST
2004 Screaming Yellow Cobra, 2.8 Kenne Bell...slow
2006 Focus ST SAP- Sold
2004 EAP SVT Focus- sold
2003 DSG Cobra 2.3 Whipple Vert - Sold
bloostd is offline
Old 09-28-2012, 11:48 PM   #2
bloostd
Fan#: 59310
Come on people, It's the weekend. Time to work on this ole' Daily Driver. Don't want to bring out the Screaming Yellow ^__^
2005 Focus ST
bloostd is offline
Old 09-29-2012, 04:04 PM   #3
bloostd
Fan#: 59310
any insight fellas?
2005 Focus ST
bloostd is offline
Old 09-30-2012, 12:54 AM   #4
SilverST05
SilverST05's Avatar
Fan#: 103209
What I Drive: 2005 Silver Frost ST
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
FF Reputation: 1 SilverST05 Good Standing Member
Next thing,
Thanks guys!
Bret
First problem sounds like the headlight switch needs replaced.
The E brake thing, I have no idea never tore apart an enrage handle, my guess is you would have to replace the entire handle assembly.
Problem 3 sounds exactly like a blower motor resister. I've sold plenty of these working at O'Reilly Auto parts. The resister has different wires with different resistance to produce the different speeds. But one, usually the high, has no resistance so when the part goes bad the one speed still works.
As far as maintenance, I would say spark plugs. I just put in Autolite XP Iridiums and have had good luck with them in my 05 ST. I would say maybe a fuel filter. Other than that making sure tires stay inflated properly.
Good luck
Brian
2005 ZX4 ST, Stealth CAI (so far)
Used to have, and will always regret selling, 1970 Mach 1.
"Everday is a good day, just try missing one."
"As soon as we're born we start dying, so you might as well have a good time."
SilverST05 is offline
Old 09-30-2012, 10:22 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
^^ I second that.
Adding that you should carefully inspect the coil boots- the rubber part that connects to the spark plug. Mine were bad around that time. The boot simply pulls off the coil- although it's easier if fold the plug end back past the coil first to break it loose. Look for cracks or other signs of obvious rubber failure. Boots cost about $5-8 each, and come with the spring and magnet inside. If you see any oil on the boots, then you need a valve cover gasket. Always install spark plugs with a dab of silver anti-seize on the threads.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-30-2012, 01:42 PM   #6
bloostd
Fan#: 59310
Good luck
Brian
Thanks Brian,
Before I moved out to D.C. I changed the fuel filter at around 68k miles. Thing was completely pluggged. Sometimes I still get hard starts every now and then when I need to give it some gas. I've replaced the battery too.
Yes, time to look into some new times, this car sat salvaged for about 3 years. It was pretty nasty when I got it, but at the price. It was a steal, and it looks like a well taken care of 05' st. haha.
So you think the headlight switch is just the switch? not a ground? Errr. You're right. If it was a ground it wouldn't show me lights at all on cluster =D. Derp.
Originally Posted by whynotthinkwhynot View Post
^^ I second that.
Excellent!
Thanks for the tips. Motorcraft plugs and coils?
Next weekend I'll be doing all this stuff.
Where would you go for an Ebrake handle? and the HVAC switch/ headlight switch?
Thanks again
Bret
2005 Focus ST
bloostd is offline
Old 09-30-2012, 01:43 PM   #7
SilverST05
SilverST05's Avatar
Fan#: 103209
Points 325, Level 6
^^ I second that.
Good call on the boots. I forgot I did that when I did the plugs. Really easy and fairly cheap for a little extra protection.
Old 09-30-2012, 01:48 PM   #8
SilverST05
SilverST05's Avatar
Fan#: 103209
Points 325, Level 6
I would say Motorcraft or Autolite plugs. O'Reilly carries both. You probably just need boots, not coils. Coils can get expensive. I used the Borg Warner boots from O'Reilly but most will be about the same. Sorry I'm pimping O'Reillys cause that's where I work.
Old 09-30-2012, 01:51 PM   #9
SilverST05
SilverST05's Avatar
Fan#: 103209
Points 325, Level 6
The headlight switch and blower resister would be available at O'Reillys :) or any parts place. The ebrake handle I'm guessing you would have to search online or salvage yards. Not on the aftermarket. And I'm doubtin the dealers would still carry it unless they are still using the same design.
Old 09-30-2012, 06:58 PM   #10
bloostd
Fan#: 59310
What kind of fuel economy are you getting in your 2.3l?
im getting like 250-300miles tank?
is it worth it to get Toms Tune? I had it on my SVTF.
This is just my daily driver.
thanks guys
2005 Focus ST
bloostd is offline
