New Steeda Front Swaybar for 2012 Ford Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-28-2012, 03:59 PM   #1
SteedaBrandon
Fan#: 96136
What I Drive: n/a
FF Reputation: 1 SteedaBrandon Good Standing Member
Check out our newly-released front swaybar for the 2012 Ford Focus!! Let me know if I can help you with anything.
Steeda Focus Front Swaybar - 2012 - $199.95
Steeda’s light weight front swaybar for the 2012 Focus is a light weight tubular design. Made from cold formed high strength steel, this bar reduces body roll, improves cornering feel, and improves overall traction during cornering. Directly replaces the factory swaybar. This 26mm bar gives a 55 percent increase in roll stiffness. Powdercoated silver for great looks and corrosion resistance.
Product Benefits
  • 55 percent stiffer than factory swaybar
  • Reduces body roll
  • Does not require any permanent modifications to car
SteedaBrandon is offline
    Quick reply to this message
Old 10-21-2012, 08:21 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,021, Level 74
Points: 13,021, Level: 74 Points: 13,021, Level: 74 Points: 13,021, Level: 74
Level Up 43% Completed
Forum Activity 99%
Awesome 26mm f bar. You guys have or working on the rear bars? Or ST rear wheel knuckle/ trailing arm assembly for your ST bar, for people w/ none ST model?
felixthecat is online now
Old 11-29-2012, 05:38 PM   #3
greg hazlett
Fan#: 93486
What I Drive: 2012 Black Ford Focus SE Hatchback
FF Reputation: 3 greg hazlett Good Standing Member
The Steeda RSB has been out for a while now.
greg hazlett is offline
Old 01-20-2013, 02:34 PM   #4
Hellman
Fan#: 98274
What I Drive: 2012,Oxford White, Focus S
FF Reputation: 1 Hellman Good Standing Member
I recently purchesed the front and rear sway bars, i installed the rear on no problem. On the front do you have to drop the subframe and install it, i was looking at it (it came with no instructions) and there is not way to get it out. or remove the steering rack. also, are the nuts torqued to yeild.
Hellman is offline
Old 01-20-2013, 02:55 PM   #5
greg hazlett
Fan#: 93486
Yes you do have to drop it and the lower the better to get the stock FSB out; I used the Ford handling pack instructions and they were pretty good, do you have them and if not I will post them here.
Old 01-20-2013, 02:56 PM   #6
greg hazlett
Fan#: 93486
http://www.fordracingparts.com/downl...htM-FR3-FS.pdf
Old 01-20-2013, 03:36 PM   #7
Hellman
Fan#: 98274
much obliged
Hellman is offline
Old 01-20-2013, 03:53 PM   #8
greg hazlett
Fan#: 93486
Good luck with it and let me know if you have any questions!
Tags
steeda
