Trans flush/filter change Worth the effort to DIY? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-28-2012, 03:31 PM   #11
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
I just did this job recently.
If you just go off the starter, you will not be doing yourself any favors.
The manual even tells you to start the motor during this process.
The engine has to run for 15-20 seconds to pump out 2 qts.
You also NEED to move the shifter through all the gears during this time.
elsolo is offline
Old 10-01-2012, 03:07 AM   #12
amc49
Fan#: 96610
Points 3,362, Level 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Level Up 8% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
The pump may have that output but you can be sure the various piping and fluid passages are gonna kill that rate horribly. Look at the video, that is NOWHERE near a 50gpm rate. 50gpm would be like a wide open water hose.
While I have simply disconnected cooler lines to do one, I have not seen a clearcut indicator on one where the fluid suddenly turns color, the fluid is heavily mixed in the converter and there is no clearcut time to stop. Refilling while pumping out probably the best way, 10 quarts in and 10 out say.
I pull the pan and put drain plug in it, then either a 2X or 3X change to get it all. I even saved the output from a 3X operation to use it in a 2X on another car to save fluid costs. I also save 3X output to use for like chainsaw bar lube and the like.
For sure if you can find gasket it's far better than gluing up the pan........
amc49 is offline
Old 10-05-2012, 10:40 AM   #13
diexodos
Fan#: 104141
What I Drive: 2001 Sand color Ford Focus ZTS
Points 169, Level 3
Points: 169, Level: 3 Points: 169, Level: 3 Points: 169, Level: 3
Level Up 38% Completed
FF Reputation: 1 diexodos Good Standing Member
AMC49, can you describe the method of putting a plug on the bottom of the transmission pan? This is the flushing method that I have used in the past on cars with plugs.
Do you see any issue with pulling the trans cooler fitting on the transmission side, run it for 10 seconds and refill? It seems to be the favorite method by most members although it does sound a little dangerous.
diexodos is offline
Old 10-05-2012, 06:42 PM   #14
amc49
Fan#: 96610
Forum Activity 39%
Drill hole in pan and install say a drain plug kit from B&M transmissions. I don't use that exact plug, I cobble mine up, long story there. The B&M will work.
I see nothing wrong with 10 seconds at a time as long as you don't run it dry. By the time you get air at the tube the pump will have possibly scored itself since a long distance between. I'd err on the side of trying to leave at least one quart still in trans.
amc49 is offline
Old 11-05-2012, 07:57 AM   #15
loki993
Fan#: 82968
What I Drive: 13 Red SE 5 speed
Points 972, Level 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
Level Up 72% Completed
Forum Activity 3%
FF Reputation: 1 loki993 Good Standing Member
Bringing this one back. Couple questions first according to the manual and the dealer the filter doesn't need to be changed until around 150k. Changing it couldn't hurt? I cant imagine that though.
Second the car still has warranty, if I were to diy the fluid change and say down the road I had issues with it could they deny the claim because I didn't have the service done at the dealer.
Oh and I called the dealer this morning just to see and its actually 179 to have the flush done and that's not even the filter!!! Robbery if you ask me. It really baffles me why they charge so much for it.
loki993 is offline
Old 11-05-2012, 08:31 AM   #16
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,723, Level 94
Points: 23,723, Level: 94 Points: 23,723, Level: 94 Points: 23,723, Level: 94
Forum Activity 13%
robbery huh? well I'm sure their rate is about $100 an hour and fluid cost. and whatever other fees they tack on.
mikebontoft is online now
Old 11-05-2012, 09:04 AM   #17
loki993
Fan#: 82968
Forum Activity 3%
Well that may be a bit harsh, but yeah. I mean especially all I'm assuming it consists of is popping the lines, hooking it to a machine and letting it go. Then refill and done. Its not just them either everywhere charges what seems to be an exorbitant price for a trans service. Most of my other dealers prices are fairly reasonable.
loki993 is offline
Old 11-09-2012, 08:56 AM   #18
loki993
Fan#: 82968
Forum Activity 3%
So I took a shot at it yesterday, not the best idea it was almost 5:30, and it needed up getting dark on me. The job looks fairly simple and straight forward and would probably take a hours of so.
Heres the problem though, my cooler lines have that, I think its a snap connector, I cant get the thing off. I checked the link in the how to, but they all seem to say push it forward, then push in on the sides and pull out. Mine doesn't seem to be able to push forward. Especially the one on the tranny side, because its right up against the fitting its connected to.
I have 2 connectors, they look about the same, except ones has black tabs and the other has blue ones. They look like it should be easy, push the tabs and pull, but its doesn't even seem like I can push the tabs all that much.
I just want to be really careful with it because if I break that thing I'm stuck. Ill be walking to the Ford dealer lol.
loki993 is offline
Old 11-09-2012, 12:29 PM   #19
elsolo
elsolo's Avatar
Fan#: 96835
rather than mess with the rubber hose and clamp,
I just unscrewed the steel fitting from the return line where it goes into the trans.
elsolo is offline
Old 11-09-2012, 03:07 PM   #20
loki993
Fan#: 82968
Forum Activity 3%
I was wondering if that wold work or not. Ill give that a try should be much easier then messing with the clip for half an hour.
loki993 is offline
