Help - 08 Transmission Fluid Mistake - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-26-2012, 08:34 PM   #1
ThaKillerKlown
ThaKillerKlown's Avatar
Fan#: 73791
What I Drive: '11 SES Sedan
Points 392, Level 7
Points: 392, Level: 7 Points: 392, Level: 7 Points: 392, Level: 7
Level Up 84% Completed
Forum Activity 3%
FF Reputation: 1 ThaKillerKlown Good Standing Member
Question Help - 08 Transmission Fluid Mistake
I have an 08 Focus w/an Automatic transmission. Its leaked a drop or two since it was new, @ 20k miles, they pulled the transmission and went through it, 55k miles later, it still drips. I recently started a new job that requires a 150 mile round trip commute so I checked my fluids, noticed it was low (fluid was right at the bottom hole, right below the crisscross patter on the dip stick) so I thought I'd pick up a quart of Mercon LV and fill it up.
My wife and I were discussing the days events after work today and I pulled the transmission dip stick and without though poured the whole quart in. I had assumed, like most cars, when the "oil" dip stick reads that low, you add a quart. Well, upon rechecking the transmision fluid level I fear I have overfilled it.
So, I have two questions, 1.) How low is the transmission fluid when its just below the crisscross pattern? and 2.) What is the simplest way to drain some of the fluid back out?
I appreciate any and all help you can give me. I don't wanna risk driving it and tearing something up!
ThaKillerKlown is offline
Old 09-26-2012, 09:51 PM   #2
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
FF Reputation: 8 st12131 Good Standing Member
I would look for a drain plug, service port or even cracking the trans cooler line open a little to get it out. As a last resort I would get a fluid pump and suck it out of the dip stick tube. Also I assume you checked the fluid, hot with the trans in N?
sent from my Samsung Galaxy SIII using FF Mobile
-Bob-
2012 F-150 EcoBoost 4X4 (work truck)
Focus S #1, Sedan Revolution #192, Rally Revolution #8, March 2012 SOTM
Focal Distortion, a Ford licensed club and FSC member.
Sgt, USMC (1999-2003)
st12131 is offline
Old 09-26-2012, 11:24 PM   #3
ThaKillerKlown
Fan#: 73791
Points 392, Level 7
Forum Activity 3%
Went with the hose method. Thanks for the help! I bet I pay closer attention next time.
Old 09-27-2012, 12:49 AM   #4
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
Glad it worked out for you, next time add just a little bit slower.
Yet another reason I drive a 5speed!
-Bob-
st12131 is offline
Old 10-04-2012, 05:26 PM   #5
md2009
Fan#: 93649
What I Drive: 09 S Sedan - Black
FF Reputation: 2 md2009 Good Standing Member
Unfortunately they don't come with a drain plug from the factory. :(
But, you can add one fairly easily if you like:
http://www.focusfanatics.com/forum/showthread.php?t=277012
Makes it a lot easier to change the fluid and filters if you can drain the pan before dropping it.
-Mike
md2009 is offline
