Normal Idle Vibration - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-26-2012, 11:54 AM   #1
Vegoose
Fan#: 104195
What I Drive: 2006 Focus ZX4 SE
Points 296, Level 5
Points: 296, Level: 5 Points: 296, Level: 5 Points: 296, Level: 5
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 Vegoose Good Standing Member
This is a noob question but I can't find an exact answer by searching the forums. I recently purchased an 06 ZX4 as a commuter vehicle and, eventually, for my son to drive. It's been a long time since I've owned 4 cyl vehicle and I'm not sure how much engine vibration at idle is normal.
I can feel a slight vibration in the steering wheel and some in the seat when idling without the A/C running. With the A/C running the engine actually seems to smooth out.
I've read on the forums to check for vacuum leaks, possible clean or replace the IAC and/or TPS. Before I do all that, just wondering if I should expect some vibration from the Duratec 2.0?
Vegoose is offline
Old 09-26-2012, 01:11 PM   #2
Dizle
Fan#: 103998
What I Drive: 2006 Black ZX3
Points 235, Level 4
Points: 235, Level: 4 Points: 235, Level: 4 Points: 235, Level: 4
Level Up 70% Completed
FF Reputation: 1 Dizle Good Standing Member
I have the same thing with my car, 75k miles. It's kind of annoying too. Also the motor doesn't rev-down, or return to idle, as quick as other cars. I've read this is normal for the PVEZ? I've changed the oil, cleaned MAF and will replace plugs and wires soon. Just seems the the rev's kind of hang for too long?
Dizle is offline
Old 09-26-2012, 04:03 PM   #3
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,727, Level 58
Points: 7,727, Level: 58 Points: 7,727, Level: 58 Points: 7,727, Level: 58
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 24%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
It could be one of the motor mounts is worn out, more likely if its higher mileage...
search around here for other posts on motor mounts, they are easy enough to replace, you have three of them; transimision mount(aka dogbone) passenger side (will leak a fluid if blown) and driver side.
I'd check the passenger motor mount first.
http://www.focusfanatics.com/forum/s...archid=6452358
rambleon84 is offline
Old 10-12-2012, 12:35 AM   #4
Vegoose
Fan#: 104195
Points 296, Level 5
Just posted this on another thread too, but changing the passenger side mount is like a magic bullet! Vibration, droning and buzzines are completely eliminated.
Vegoose is offline
Old 10-14-2012, 10:37 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,911, Level 74
Points: 12,911, Level: 74 Points: 12,911, Level: 74 Points: 12,911, Level: 74
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
I can feel a slight vibration in the steering wheel and some in the seat when idling without the A/C running. With the A/C running the engine actually seems to smooth out.>>>> The a/c kicks the motor to a slightly higher rpm.<<<<
Yes, its a 4 cyl & thats the way it is. Your going to get vibes thru the S/W. You should see my wheel vibrate w/ bsd & cams at idle. No big deal.
felixthecat is offline
Old 10-15-2012, 09:18 AM   #6
Focusblackzx5
Focusblackzx5's Avatar
Fan#: 95212
What I Drive: 2012 Mitsubishi Lancer
Points 1,323, Level 20
Points: 1,323, Level: 20 Points: 1,323, Level: 20 Points: 1,323, Level: 20
Level Up 23% Completed
FF Reputation: 1 Focusblackzx5 Good Standing Member
yup mine too, same thing, S/W vibrations^^ even with 3 brand new motor mounts. But with intake and exhaust vibrations, it's a lot worse eheh^^
2012 White Mitsubishi Lancer 2.0L : New car
2005 Black Ford Focus zx5 SES : Trade In
2003 Arizonna beige Ford Focus SE : Sold
Focusblackzx5 is offline
Old 10-15-2012, 10:27 AM   #7
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
Yeah, but it worth it thou.
Old 10-30-2012, 04:18 PM   #8
Dizle
Fan#: 103998
Points 235, Level 4
UPDATE
Went from annoying vibrations at idle and throughout the rpm range while driving to buttery smooth like a new car with no vibrations!
I inspected the passenger motor mount and it looked to be in fairly good condition. Went ahead and replaced it anyways and the vibrations are COMPLETELY GONE! Feels like a brand new car at idle and while driving, it seems like she's not even running it's so smooth.
Anyone with vibration issues at idle I would say change the passenger mount, took like 20 mins and fixed all my vibrations issues. After much research on here I went with DEA brand motor mount, didn't want to spend 2x that for a Ford part. Hoping the $60 mount lasts a few years, if not at least I know it'll be worth it to buy a Ford part and it WILL solve my annoying vibration issues if the come back in the future!
Dizle is offline
Old 10-30-2012, 06:27 PM   #9
Vegoose
Fan#: 104195
Points 296, Level 5
Originally Posted by Dizle View Post
UPDATE
I had the exact same experience. I did, however, buy the Ford part just avoid any problems with a non-OEM part. FYI, you can find the Ford part on Ebay for around $85 incl shipping. Good to hear the DEA part worked for you. I think I might replace the drivers side mount soon so maybe I'll order aftermarket.
Vegoose is offline
Old 10-30-2012, 06:46 PM   #10
PRSman25
Fan#: 103893
What I Drive: 2001 Black ZX3
FF Reputation: 1 PRSman25 Good Standing Member
Why are you guys buying such expensive mounts?
O.o
Rock Auto has these mounts for almost half...
PRSman25 is offline
