World record MPG? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-26-2012, 10:45 AM   #21
cobie56
Fan#: 84403
going downhill routinely gives me over 150mpgs on my scan gauge.....ha ha now if it'd only give me half that in normal driving i'd be happy.
cobie56 is offline
Old 09-28-2012, 02:15 PM   #22
FocusOnMeNow
FocusOnMeNow's Avatar
Fan#: 97757
What I Drive: 2012 Sterling Gray SE 5 Speed
FF Reputation: 1 FocusOnMeNow Good Standing Member
Originally Posted by gkirk View Post
nope, in neutral the car uses gas to idle. in gear while coasting over a certain speed, it uses absolutely zero.
Why is that? Do you know what speed the car has to obtain in order to shut off the engine?
FocusOnMeNow is offline
Old 09-28-2012, 02:22 PM   #23
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,060, Level 67
Points: 10,060, Level: 67 Points: 10,060, Level: 67 Points: 10,060, Level: 67
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Aggressive deceleration fuel shut off (A-DFSO) cuts fuel when the throttle is closed and the car is in gear. Essentially you are not injecting any fuel and the momentum of the car is driving the engine as an air pump through the wheels. Where as in neutral you've disconnected the engine from the transmission and therefore have to burn fuel to keep it running.
However there are a few conditions that need to be met, such as the initial vehicle speed being sufficient/ load sufficient to support this condition. It appears to work down to 1500 rpm or so afaik.
suss6052 is online now
Old 09-28-2012, 07:31 PM   #24
FocusOnMeNow
Fan#: 97757
So your saying, below 1500 rpm is when the fuel cut occurs?
Sent from my DROID BIONIC using Xparent Blue FF Mobile
Old 09-28-2012, 08:06 PM   #25
Albarry
Sonic Crew #016
Albarry's Avatar
Fan#: 87877
What I Drive: 2012 Sport completely stock, DCT
Points 3,539, Level 37
Points: 3,539, Level: 37 Points: 3,539, Level: 37 Points: 3,539, Level: 37
Level Up 26% Completed
FF Reputation: 8 Albarry Good Standing Member
my best to date, sorry for the blur,
[IMG][/IMG]
(STORM THE ALBATROSS) SC016 RR054 SR251 [HOONIGAN]
Albarry is offline
Old 09-28-2012, 09:20 PM   #26
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 22%
I said down to, that means from any engine speed above this point i.e. from 6500 rpm down to 1500 rpm.
No, below 1500 rpm the fuel cut would stop happening. I.e. you need to have sufficient vehicle and road speed, although I think it might be active down to 15 mph, i.e. that's the minimum speed when you could be running under the fuel shut off. However I don't know the exact thresholds, but its been discussed a myriad of times.
