SVT running but only just - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2012, 09:36 AM   #1
Davva
Fan#: 41632
FF Reputation: 1 Davva Good Standing Member
Hi All
I have just replaced my head gasket and put the car all back together and it will start and run but only just. I have to keep the gas pedal pressed or the car will just cut out.
I replaced the water pump, serp belt, timing belt, both tensioners, plugs and wires while I was there
I'm getting 1518 and 1520 codes on the OBD.
I was getting the 1520 before the gasket blew so I don't think that's what's making it run so rough but I don't know for sure.
I'm not sure where to start diagnosing this so hence this post.
What would be the best way to fault find this?
Thanks
Davva
Davva is offline
Old 09-25-2012, 02:37 PM   #2
flaurencelle
flaurencelle's Avatar
Fan#: 35294
What I Drive: Ford Focus 06 ZX4 SE GFX + 2002 SVT
FF Reputation: 1 flaurencelle Good Standing Member
Looks like you forgot to connect back the IMRC Throttle Cable on the Intake Manifold. Look to the right of the Manifold. Anyway, you must remember having removed this cable in the first place!
The IMRC will pull the cable when the engine starts, therefore the Intake lenghts is shorter and this is why you get this code. Might also affect the idle.
Hopefully your IMRC is still good..! I have doubts if you had the code before you replaced the gasket! Look around on the forum, most of the time its easy to fix (A bit of electronics).
Other than that.. check your connections and vaccuums. I removed the Intake several times and I did get bad hesitation because i forgot some vacuums and connections.
Good luck!
flaurencelle is offline
Old 09-26-2012, 09:02 AM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,900, Level 100
Points: 51,900, Level: 100 Points: 51,900, Level: 100 Points: 51,900, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
Sounds like you dont have your cam timing correct , the IMRC wont keep it from idling and driving properly
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 09-26-2012, 11:23 AM   #4
Davva
Fan#: 41632
What is the best way to get the cam timing correct?
And is there any way to check it?
Davva is offline
Old 09-26-2012, 10:51 PM   #5
Davva
Fan#: 41632
Ok guys, I'm really stuck now.
I stuck the pin in and turned the engine to TDC. Then I took the valve cover off and I checked the slots on the cams. They seem to be right where they should be. I slotted a bar in there and it fits in nicely. (it's not the proper bar but it's 4.5mm and the slot is 4.9mm so I think that's ok or does it HAVE to be real tight in there?)
I just did a compression check and the cylinders are all at 50PSI. That's way low according to most of the figures I've seen previously. But what would cause ALL of them to be that low? I'm confused.
I really don't know what to do next so any suggestions would be greatly appreciated.
Thanks
Davva
edit: I've taken a pic of the bar in the cam slots. It's in my album. The pin is in the engine and I cranked the engine round to TDC. The bar and the slots look right to me. Can someone confirm this for me please?
Davva is offline
Old 09-27-2012, 11:07 PM   #6
drostedrummer89
I <3 my SVT
drostedrummer89's Avatar
Fan#: 69059
What I Drive: 2002 Sonic SVT
Points 5,199, Level 46
Points: 5,199, Level: 46 Points: 5,199, Level: 46 Points: 5,199, Level: 46
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 8 drostedrummer89 Good Standing Member
Buy-Sell-Trade Rating: (10)
If you get engine near tdc, insert pin, rotate engine clockwise and feel it hit the pin, then the bottom end is for sure at tdc. Cam slots only work one way. If you got the bar in, then its the cylinder head is at TDC..
Low compression is normal for svt from what I'm told, due to the VCT.
Matt
Posted via FF Mobile
drostedrummer89 is offline
Old 09-28-2012, 12:20 AM   #7
Davva
Fan#: 41632
Matt
Thanks for the input Matt. I had another look at the cams and there's no way that the bar will go in with the cams the other way round. I turned the engine round until it hit the pin and the bar slipped in very easily so I'm thinking this is right.
So the timing is right and I've changed the plugs and wires.
I don't know what to try next.
Any ideas?
Davva is offline
Old 09-28-2012, 09:05 PM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 31%
If you want to call me we can kick around some thoughts if you like
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-28-2012, 11:36 PM   #9
Davva
Fan#: 41632
Thanks Tom
I will call you tomorrow. (Sat)
Davva is offline
