Old 12-23-2012, 03:22 PM   #21
Sapperstang
Fan#: 27847
FF Reputation: 1 Sapperstang Good Standing Member
Buy-Sell-Trade Rating: (-1)
Originally Posted by iminhell View Post
@ 160K on a stock alternator, just consider it preventative maintenance. It'd of gone out soon anyways.
Do check the "Hatch Wiring" though. It was my initial thought of why your problems started and I didn't see anyone mention it (odd).
I did see that in another thread somewhere. If you mean the rubber covering connecting the body to the hatch it appears perfect on the exterior. I agree on the alternator so while it may have went awhile I am glad it is out of the way. Thanks.
03 zx3
Sapperstang is offline
Old 12-23-2012, 04:22 PM   #22
Nevin W
Nevin W's Avatar
Fan#: 98043
What I Drive: 2002 Liquid Grey Metallic Wagon
FF Reputation: 2 Nevin W Good Standing Member
The external of it does bit matter, you need to pull back the boot and actually look at the wires. Good chance that they are broken in areas. Even with it fixed you should try to pull the boot off and take a look. Good luck.
Nevin
PNW Crew #45
Originally Posted by Malibooya View Post
Clearly this means that Ferrari is Swedish because owls only fly at night.
Nevin
Nevin W is offline
Old 12-24-2012, 04:26 PM   #23
Sapperstang
Fan#: 27847
Will do. I noticed awhile back while doing the oil or timing belt that nearly all of the wire coverings underhood are either cracked or gone completely.
03 zx3
Old 12-26-2012, 10:52 AM   #24
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
FF Reputation: 15 a_2000_se Great Standing Member
Replacement batteries seem to have smaller diameter posts on them than the OEM battery - at least SEARS batteries do. This makes the battery terminal clamps a potential 'lose' fit.
The battery terminal bolt can be fully cranked down and you may still have a loose fit - especially if the terminal/post has been cleaned many times or excessively.
They make a battery post product that fits over the post to enlarge it for a better fit to the OEM terminal clamp. I don't know how well they work/fit but it might be easier than replacing the terminal clamps. It also may just be another point for corrosion to enter a connection - unseen.
Dielectric grease is always good for a battery connection to keep corrosion to a minimum.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
40k+ miles, now jinxed?
a_2000_se is offline
Old 12-26-2012, 07:26 PM   #25
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
I've never memorized which one but one post is always smaller by design, dunno why they do that..........
amc49 is offline
Old 12-31-2012, 05:57 AM   #26
Sapperstang
Fan#: 27847
So far it is fine.
03 zx3
