#1 | ||||
This is odd
Hey fellas. Car is a 03 ZX3 w/160K miles. Bought new. Wife went to leave for work and car was dead. Yesterday she was cleaning the interior and took a long break and left the doors open. Figured the interior light killed the battery so I jumped it off my truck. Started right up.
I let it run awhile to charge the battery but when I went out after about 30 mins the car was not running and the battery was dead again. Painters were coming to I jumped it again to move it out of the way. Noticed right off that anything electrical that was on caused an odd clicking near the fuse panel area as well as a noise that sounded like static (with car running). Hatch wasn't latched so the dash light for that was on which caused the noise. Pushing the brakes (lights) caused it too. Turn the headlights on and it immediately killed the engine. Battery was dead again as well. Any thoughts fellas? I found the clicking at the fuse panel odd. Hopefully something simple. Never have had an electrical issue with this car before. Thanks in advance.
03 zx3 |
Remove Advertisements |
Fan#: 1
#2 | ||||
Could be a bad alternator or a weak battery, even really corroded terminals on the battery
D23 crew #27, the look on their face when they see foci taillights |
#3 | ||||
Battery is only a year old. Terminals are not corroded. A bad alternator will cause the noises in the fuse area when electrical devices are on?
03 zx3 |
#4 | ||||
There are several relays at the fuse panel.
If one of them was experiencing an intermittent open (or short) condition, you would hear the relay(s) clicking on/off. I am going with loose connection or bad ground, the clicking is just a symptom of the general problem. |
#6 | ||||
would suggest checking the alternator first,its an easy check if you have a multimeter to see if it is charging, are you sure the interior light is off ??? (just checking) and you could also check to see if there is a draw from the battery by disconnecting the negative battery and using your multimeter to check that, if it is a draw from the battery well that a hole different ball game but dose sound very like the alternator only had a Renault last month doing the exact same thing
hope this helps the phantom |
#7 | ||||
I jumped it again when I got home. It started right up and seemed fine. But after idling for about ten minutes it started to act up again. Popping static noise over the speakers and the clicking from the fuse panel. Try to move it and the engine stutters. I turned it off and when I went to try to restart it it was dead.
03 zx3 |
#8 | ||||
Sounds like the alternator. Jump it and let it idle for a few minutes. Put a multimeter on the battery terminals. Anything less than 12.5vdc means it isn't being charged. If it is over 12.5 then shut the car off and check again. If it is at 11 and dropping before your eyes then you have a faulty battery.
#9 | ||||
If the alternator is good it should hold at 14 volts on a 12 volt battery. It does sound a lot like an alt issue. Do you have am aftermarket head unit/speakers/amplifier?
North East Honda Killer OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane |
#10 | ||||
Car is bone stock. Battery was tested and was good. It was also fully charged but the car acts dead with the exception of the blinking light on dash.
03 zx3 |
| Thread Tools | |
| Display Modes | |
