SYNC Update Available on Focus!!! - Page 64 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2012, 02:45 PM   #631
lewisra
Fan#: 93289
What I Drive: 2012 Tuxedo Black SEL
Points 1,395, Level 20
Points: 1,395, Level: 20 Points: 1,395, Level: 20 Points: 1,395, Level: 20
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 3 lewisra Good Standing Member
Originally Posted by smizak View Post
will give it a shot guys, thanks
Coper has it correct. You may need to put your phone in Bluetooth discover mode. I have to on my basic phone, but not sure of others.
lewisra is offline
Old 10-24-2012, 02:51 PM   #632
lewisra
Fan#: 93289
Originally Posted by chum567 View Post
Got the update...went to dealer with other issues and said I heard there was a new update he said yes but he could only give it to me if I had issues and I told him FM stations don't always show and he fixed it...everything seems fine right now.
Can you check just to confirm what version you have.
On MFT, Press "gears" in bottom middle, then Help, Then system information. It'll say mid-way down something to the effect of CCPU S/W version 4.28.12xxx_product.
lewisra is offline
Old 10-24-2012, 02:54 PM   #633
lewisra
Fan#: 93289
Originally Posted by lewisra View Post
Was it working after you installed v3.2.2?
Have you tried;
1. deleting and re-pairing
2. reverse pairing
3. remove battery from phone while it's on, then connecting BT
4. delay ed reboot.cab(all one word)
Just to be clear these are 4 different things you can try, don't have to do all 4 if one other works.
lewisra is offline
Old 10-24-2012, 03:50 PM   #634
Dysan911
Fan#: 95746
Its funny after my fix. One of the symptoms of 3.22 I noticed was occassionally my home screen would show "CONNECT A PHONE". but when I went into the phone menu all I could do was disconnect it. So it was connected. I figured this was possibly part of the flawed install that resulted in my climate control loss and once the dealer flashed everything back it would likely resolve that too.
NOPE!. Still shows "CONNECT A PHONE".
Also lastnight on the way home I tested a phone call using the handsfree and it changed my AM station to random FM station. Wow!.
2012 FF Ti HB Platinum White Tricoat, Built 12/11, 401A + Parking Technology Package and MFT w/NAV at 3.5.1
Dysan911 is offline
Old 10-24-2012, 09:44 PM   #635
oritpro
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 oritpro Good Standing Member
Any chance you can post a copy of or let us know what was on your work order? I'm trying to educate my dealer.
The work order says "contacted hotline for any known concerns hot line replied reprogram APIM and retest. performed APIM reprogram as per shop manual after reprogram found OK." Sure enough, it did the trick!
oritpro is offline
Old 10-25-2012, 07:52 AM   #636
smizak
Fan#: 92058
What I Drive: 2012 Black SEL
FF Reputation: 2 smizak Good Standing Member
Got Bluetooth MAP working again, it appears it was an issue with my phone. Sorry Ford. Not really.....
smizak is offline
Old 10-25-2012, 08:27 AM   #637
Dysan911
Fan#: 95746
How?
Dysan911 is offline
Old 10-25-2012, 09:14 AM   #638
chum567
Fan#: 86507
What I Drive: 2012 Sterling Gray Focus SEL
FF Reputation: 1 chum567 Good Standing Member
can you check just to confirm what version you have.
On mft, press "gears" in bottom middle, then help, then system information. It'll say mid-way down something to the effect of ccpu s/w version 4.28.12xxx_product.
4.28.12156
chum567 is offline
Old 10-26-2012, 04:08 PM   #639
georgegren
georgegren's Avatar
Fan#: 96328
What I Drive: 2013 Black 5 door Titanium
Points 17, Level 1
Points: 17, Level: 1 Points: 17, Level: 1 Points: 17, Level: 1
Level Up 33% Completed
FF Reputation: 1 georgegren Good Standing Member
Anyone else having an issue with losing the Sirius based sync services, ie TRAFFIC, WEATHER, etc.. since their update?
I keep losing them, if I do a Master Reset, they come back for a day and then lose connection again. I tried having Sirius resend a signal, that doesn't work.
Any ideas?
georgegren is offline
Old 10-26-2012, 04:20 PM   #640
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,491, Level 21
Points: 1,491, Level: 21 Points: 1,491, Level: 21 Points: 1,491, Level: 21
Level Up 91% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Any ideas?
Yep. It used to take about 5-7 days before I lost them and had to reboot to get them back. Since 3.2.2 it doesn't even last 2 days. I have done 3 reboots since Monday (I do reboots, I hate Master Resets because it wipes out all of the presets, wallpaper, phone, etc.) In all honesty, it didn't work that great with 3.0.2 for me and like I said I had reboot with that version as well, just not this often.
Call Ford and they'll tell you it is Sirius' fault and they are not sending the signal. Tell them that it is amazingly coincidental that after every reset/reboot the signal is suddenly there. Ask them how Sirius knows you just did a reset/reboot and suddenly knew to send out a signal. You will get nothing but silence on the other end of the phone (trust me, I've done it).
I've tested every single thing I could think of to fix this/get it working better. Everything I have tried leads me one conclusion - this is entirely a problem with MFT and has nothing to do with Sirius.
Worked flawlessly when I had 2.11.
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
