No start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-23-2012, 11:25 AM   #1
zip247
Fan#: 104148
What I Drive: 2005 Ford Focus zx4
FF Reputation: 1 zip247 Good Standing Member
No start
I have a 2005 Ford Focus zx4. This morning I started my car fine and drove to the local coffee shop. After getting my coffee and going back out to my car it will not start, no clicking, no lights, no radio, no nothing. What I find even more odd is that I can not even put the car in neutral when i turn the key.
New battery was installed about 2 months ago.
Any ideas would be greatly appreciated.
Zip
zip247 is offline
Old 09-23-2012, 11:34 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,528, Level 98
Points: 27,528, Level: 98 Points: 27,528, Level: 98 Points: 27,528, Level: 98
Level Up 18% Completed
Forum Activity 13%
You should check all your battery terminal connections. It's likely one is loose, and that will give the symptoms you've described. Most likely it's the negative battery terminal, but it could be either one.
The trans won't shift into N without power, but you can force it into gear by using the emergency parking pin release detailed in the owner's manual. That's how you get a non-starting car to tow. You can use the key to press on a point in the shifter console to release the shifter. That's all cars, but your manual will give the specific location. It's typically hidden by a plastic plug that looks out of place.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-23-2012, 11:40 AM   #3
zip247
Fan#: 104148
I will check that when I get my car buddy out of bed and to my car. I did pop the hood and wiggle the battery terminals and they seemed tight. We will remove the terminals and then reconnect and see if that solves the problem.
I will let you know.
zip247 is offline
Old 09-23-2012, 02:26 PM   #4
zip247
Fan#: 104148
There was a lot of corrosion on the battery terminals. We disconnected the battery, cleaned up all of the corrosion and reconnected the cables. The car started just fine and runs like a champ.
Thanks for your advice.
Zip
zip247 is offline
Old 09-23-2012, 02:33 PM   #5
the phantom
Fan#: 73988
What I Drive: 2007, Panter Black, focus
FF Reputation: 1 the phantom Good Standing Member
just a bit of advice while cleaning battery terminals with corrosion on it
1 boil kettle
2 make tea (just kidding)
3 pour boiling water over terminals
4 put pure patrolium jelly on it
5 and bods your uncle
hope it helps
the phantom is offline
