#1 | ||||
01 ZX3 Rear wiper and hatch non function
I have an 01 ZX3 the rear wiper and the hatch switch do not work I suspect there is a short in the wiring but would like more ideas or information before I rip the car apart. Are there known problems with these not functioning after a while? i can still get into the hatch but i must use the key. are there any other possibilities that could explain both not working short of coincidence.
Remove Advertisements |
Fan#: 1
#2 | ||||
i dont know if there is one for this problem but have you checked fuses?
"If I'm not driving than I'm not living" - ME Hatch Nation #166 |
#3 | ||||
check fuses then go to the connector there is a simple method that you should always follow when checking electrical problems always check the easy fix first
R.I.P the 01 red zx3 served me for less than one year I loved it so much I bought a newer 04 black zx3. |
#4 | ||||
Start at the hatch wiring for the wiper. The button on the dash for the hatch are known to fail. Sometimes a cleaning helps.
#6 | ||||
saved from the grave
^^^^^This, every time you have an electrical problem with a hatchback, this is the first place to look, its been said over and over..........goodluck (and yes, mine did the same cracking and I had all kinds of electrical surges and odd behavior)
#7 | ||||
mine didnt work because the rubber seal on the outside was lifted a little and water kept seeping in and cause the cogs to seize up with muck,grime and rust
keith4594 |
| Thread Tools | |
| Display Modes | |
